Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 13th May 2008, 07:22 PM   #21
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: which transformer?
Originally posted by gychang
I will be following this thread, but I get confused on the transformer to get about 55W/ch in stereo from GC.
Anyone know the website for the appropriate transformer?, need cost-effective solution for the classic GC kit from Peter.
Any of the model here work?
http://www.apexjr.com/miscellaneous.html#Toroids
or here:
http://www.partsexpress.com/webpage....e_ID=3&x=0&y=0
do I need one or 2 transformers. (please say 1 )
gychang
Partsexpress is more suitable choice. Go with a single Avel 250VA transformer, either 2 x 25V for 8 ohm speakers, or 2 x 18V for 4 ohm speakers.
I will post tomorrow more info how to wire single transformer.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 13th May 2008, 07:42 PM   #22
Colin is offline Colin  United Kingdom
For UK Gaincloners, this Airlink transformer is a good substitute for the 300VA Piltron. Kensai (I believe) recommended Airlink on another thread. I received my Airlink toroid earlier this week and it seems a very solid unit. One offs are about £32 including delivery.
Old 13th May 2008, 08:08 PM   #23
gychang is offline gychang  United States
Default Re: Re: which transformer?
My speakers are 8Ohms.
Is this the right one, I only need one right?
http://www.partsexpress.com/pe/showd...number=122-625
I will be looking forward to your instructions.
gychang
Old 13th May 2008, 08:15 PM   #24
Yes, Avel Y236652 250VA 25V+25V Toroidal Transformer is right choice for 8ohm speakers.
If you don't mind spending a bit more, Avel Y236750 330VA 25V+25V is a good choice too.
www.audiosector.com
Old 15th May 2008, 12:39 AM   #25
Bluto is offline Bluto  United States
Hi Peter -
My boards just arrived about an hour ago. The quality is very impressive. Thank You again.
How many questions do you want here on list vs. via PM?
I already have several 'dumb newbee' ones myself.
Bluto
Old 15th May 2008, 12:46 AM   #26
No problem with all the questions in here.
www.audiosector.com
Old 15th May 2008, 02:30 PM   #27
This concludes the assembly and we have two separate amp channels with separate bridge rectifiers. All is needed now is to connect 2 transformers (one per channel) as per schematic posted here: http://www.diyaudio.com/forums/attac...amp=1210694958 , connect the input (SG for ground, IN for signal input) and output ( OUT to positive binding post, OG to negative) and we have a working dual mono amplifier.
And this is how one complete amp channel looks when wiring is done. The transformer primaries are not connected yet, and I will explain it at later stages.
I usually use 26ga solid core wire for input signal and I never found a need for shielded cable. I normally don't even twist them, but it's a good idea anyway.
For speaker connections I use 19ga stranded wire.
See this table for American Wire Gauge Table:
http://cc.msnscache.com/cache.aspx?q...b17&FORM=CVRE2
www.audiosector.com
Old 15th May 2008, 02:33 PM   #28
Those are some tools you may find useful for wire insulation stripping:
www.audiosector.com
Old 15th May 2008, 04:55 PM   #29
By stereo version I mean the use of a single transformer powering both channels. You could still use two separate rectifiers boards, but depending on wiring it may produce hum in some systems, so I always stick with a single rectifier board when using one transformer.
For demonstration purpose, I will install all the boards inside 3 x 1.5" U-channel, 1.25" aluminum extrusion. For normal listening, this is enough to dissipate heat from the chips, and when things get hot, you can always attach it to larger aluminum panel.
I will show a version with a potentiometer, and without, so stay tuned.
www.audiosector.com
Old 20th May 2008, 01:45 AM   #30
Default bump!!!
Hello Peter,
Great thread.
My buddy just ordered 2 3875 classic kits last week. I will be the builder. One kit for my studio monitors and one kit for his home stereo.
Can't wait for the rest.
I will be building 2 stereo versions.
I also had a question about internal wiring of the inputs/outputs and passive pot.
I use mogami 2549 mic cable it is OFC 22 gauge shielded.
DC Resistance
Inner Cond. 0.058W/m(0.018W/Ft)
Shield 0.013Ohms/m(0.004Ohms/Ft )
Capacitance at 1kHz, 20°C
K0 76pF/m(23pF/Ft)
K1 11pF/m(3.4pF/Ft)
I use this for all my interconnects and mic cable in my studio.
Would this be ok/good to use for the input and output (and pot) wiring?
Out,
Robert
p.s. you have amazing machining skills.
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 365 4th October 2011 08:19 AM
Page generated in 0.08768 seconds (67.26% PHP - 32.74% MySQL) with 11 queries
