Commercial Gainclone kit- building instructions - Page 29 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 2nd November 2008, 06:19 PM   #281
Peter you tried some MK120 instead MK132 in some of your amps? will sound diferent if use mk120 instead mk132?
Old 2nd November 2008, 06:31 PM   #282
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Never tried those as they were not generally available from the usual distributors, when I was developing minimized GC circuit.
From spec sheet, they look basically the same as MK132, just smaller. Could be a difference in sound, but if any, it will be rather subtle.
BTW, in a GC input shunt and feedback position MK132 were the best resistors I could find, better than Caddock TF020 or Vishays S102.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 2nd November 2008, 10:55 PM   #283
Just to show you the possibilities with implementation of those kits, here's a custom 4 channel amp that will be used in an active system.
www.audiosector.com
Old 2nd November 2008, 11:09 PM   #284
mikejennens's Avatar
Peter,
I've looked through this thread and can't quite answer my own question. I have my rectifier board wired to my transformer as you instructed me earlier. I'm getting 37.8 VDC between V+ and PG+ and the same on the negative side. Is that OK?
Secondly, since I'm only using one rectifier board do I just run the two amp boards off the rectifier board in parallel?
Thanks again for all your guidance.
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Bjorn's PS95 TABAQs
Old 2nd November 2008, 11:15 PM   #285
If you measure between V- and PG- you should be getting -37.8V. Everything else is correct.
An example for your second question can be found here: http://www.diyaudio.com/forums/attac...amp=1213593687
www.audiosector.com
Old 3rd November 2008, 04:35 PM   #286
Default Wood or metal case?
I'm finishing up my first Audiosector chipamp. Does it make a difference if I use a metal case or a wood case, other than obvious safety issues? It seems I read somewhere that these kits should be put in a metal case.
I have a Velleman kit I built and have it in a wood (cigar box) case and it woorks fine.
Any ideas or suggestions or greatly appreciated!
Mike
Old 3rd November 2008, 06:23 PM   #287
A metal case provides shielding and heat dissipation. In many locations shielding is not critical and heat dissipation can be taken care by heatsinks. So a wooden case is certainly possible, here couple examples:
Convection cooling in a GC amp
http://www.mother-of-tone.com/index.htm
www.audiosector.com
Old 3rd November 2008, 11:37 PM   #288
Rarely I do see smoke when testing newly built equipment but today it was not a case. The amp pictured few posts earlier had a series connection problem where each secondary was powering both positive and negative rail bridges, which obviously couldn't work, even though making for a very elegant layout. Now you know why I promote single rectifier boards when using single transformer In this case though, I wanted to separate multiple filter caps with bridges.
Here how it should be wired correctly
www.audiosector.com
Old 8th November 2008, 03:57 AM   #289
Default Finished my First 3875!!!
I just finished my first AudioSector chip-amp. It's playing music as I type this. Sounds great so far.
One question...with no music playing and the volume up a little I get a very slight background noise, almost a hum. It goes up and down with the volume. I did the star ground as Peter advised. When I touch the RCA connectors, one or both, the noise goes away. I don't have the RCA's mounted yet, as I only have everything on a 12" X 12" board since I just finished assembling it. Any ideas?
I'm looking forward to getting this kit in a box/cabinet. I'll post some pics once I have it mounted.
Thanks for your quick answers on all my questions Peter. This is a great thread, project, hobby!
Mike
Old 8th November 2008, 05:31 AM   #290
Hi All
I'm in the final stages and have a couple of questions:
RLED/R3 - According to Ohms Law, if I figure the supply voltage to be 25v, my green LED to have a voltage of 2.1v (a guess) and I want to supply it with 15ma, then a suitable value for RLED would be 1.5K ohm?
CHG and the earth from the mains IEC get connected together at a star ground, for instance one of the bolts holding the IEC to the chassis plate?
Many thanks in advance
Matt
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 09:07 AM
Copyright ©1999-2017 diyAudio
