Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 19th August 2008, 04:28 PM   #221
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
If I ever need heatsinks, I usually buy them locally, surplus.
To order kits contact me through forum mail.
Old 19th August 2008, 07:35 PM   #222
zebra100 is offline zebra100  United Kingdom
Thanks Peter. I did mean the copper bars. Is there a website for the supplier?
Old 19th August 2008, 08:11 PM   #223
Here it is: http://www.metalsupermarkets.com/
Also, this place stocks copper bars: http://www.mcmaster.com/
Old 20th August 2008, 07:31 AM   #224
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
Originally posted by Peter Daniel
The diagram included with kits shows 2 options: parts and connections marked in red are for parallel configuration only, those marked in green are for stereo or bridged setup: http://audiosector.com/lm4780%20amp.pdf
More info was posted on a forum: http://www.diyaudio.com/forums/showt...565#post636565
It is no problem to add larger caps; depending on a system they may bring improvement, but not neccessarily.
the diagram provided shows the jumper in place for parallel work. Looking at the National LM4780 datasheet i need to tie the inputs (in and in ground) for bridged mode so that i only have one input. This suggest i need to put the jumper in place for bridged setup.
can anyone confirm this ?
Old 21st August 2008, 05:37 AM   #225
The jumper is in place for parallel setup only. For bridged operation we want to keep inputs and outputs separately, as they are run in opposite phases.
Old 21st August 2008, 06:51 PM   #226
Ted205's Avatar
but i require only one input per chip. Sorry i'm getting abit confused over the bridged setup.
I understand the schematic in the datasheet where one internal amp is non inverted, the other is inverted resulting in the output opposite phases, doubling the available signal 'swing'.
Looking at the instructions with the kit i can't see how this is achieved.
Sorry if I'm being stupid
Old 21st August 2008, 07:49 PM   #227
My kit is configured in a such a way, that even in bridged setup none of the amps is inverting: that way, with those boards, you can use half of the kit only, with a single chip wired for stereo operation. Of course, bridged configuration requires balanced signal to the amp, as it will not convert unbalanced to balanced.
If you require one input per chip, you have the option of using each chip in parallel for more current output, or one chip only (non parallel) with two separate channels.
Old 24th August 2008, 01:11 AM   #228
F1 FAN is offline F1 FAN  Canada
If using a 10k pot should I just omit the 22k R2?I will also be including an input cap after the pot and R1 will be 1k.
THanks
Old 24th August 2008, 06:04 AM   #229
The 22k input shunt resistor is there for a reason: with simplified GC schematic (and 22k feeedback resistor) it limits the output DC offset.
If you use the coupling cap after the pot, that resisotor is neccessary. If there is no cap, you could omit the R2 resistor, but in case a pot fails the resistor is there for protectioion.
Old 24th August 2008, 12:20 PM   #230
CFT is offline CFT  United States
Hi Peter,
I understand that the power supply filter caps should be close to the chip's pins.
From your experience, would positioning those caps with PC board traces that are 2 to 3 cm away from the chip make a sonic difference? Just curious.
Thanks!
CFT
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
