Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 23rd July 2008, 06:15 PM   #191
mubeen1983 is offline mubeen1983  Australia
Originally posted by Peter Daniel
I expressed some thoughts on further upgrades to a premium kit here: http://www.diyaudio.com/forums/showt...32#post1231532
More reading on capacitor comparisons can be found in those links:
http://www.diyaudio.com/forums/showt...431#post574431
http://www.diyaudio.com/forums/showt...230#post581230
Better case is certainly important if you want to get the best out of the amp. My present amp was described in this thread: http://www.diyaudio.com/forums/showt...609&highlight= and here I pushed the GC concept as far as I thought was possible
Personally, I don't like buffers in the amp, the buffer should be placed with a source. A simple fet buffer works fine with NOS DAC, one such example is buffer described in Figure 15C in Borberly article: http://www.borbelyaudio.com/adobe/ae699bor.pdf
At the amp's input, a swtching attenuator is usually preferred (25k or so).
Thanks very much for the valuable info Peter. I checked and read through the links you have given here. And I completely agree that GC in its original form is probably the best GC. As there is certain naturalness and delicate harmonic balance in its sound which might easily be lost by sticking anything before or after it. If aint broke, dont fix it, so i wont
But i see that you suggested using BG 100uf N caps on amp boards. I would like to try this mod and see if i can get better clarity in vocals and higher mids. I understand that i would need to replace existing Panasonic FC caps on amp board with same number of BG 100uf N caps? Please correct me if i am wrong.
Saw your case work and i must say its a masterpiece. simply awesome! i would love to build something like that someday. For now, lets see if i can build a simple and neater case
Sorry for my ignorance but where exactly do we use the switched attennuators? Is it a substitute for volume pot?
Also, currently i am using a 100K pot for volume control as it was the only one available at the time i was building. I still need to order the Nobel one. Does this value affect the amp in anyway? I should be using something in range of 20-50K, isnt it?
Can i safely remove the input resistor without affecting the amp in anyway and would it help to improve sound?
Cheers!
Ignorance is bliss. Knowledge is enemy of faith.
Old 23rd July 2008, 09:57 PM   #192
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Yes, the 220R input resistor in most cases can be removed, especially if you have potentiometer.
I actually meant stepped attenuator in place of potentiometer, which is probably more popular term, a recent discussion can be found in Blowtorch thread: http://www.diyaudio.com/forums/showt...61#post1568061
100k will work but it's a bit too high, the potentiometer should preferrably be in a 10k-25k range, 50k being maximum.
On amp board my first choice is indeed BG N 100/50. For mids and highs you don't need any additional caps here and those small BG N will give you the best sonic signature I experienced so far from a GC. However, for full range they are not enough to smooth PS ripple and some hum will be present; that's why additional BG STD 1000/50 are placed at rectifiers. The latter may also further improve bass response.
To order kits contact me through forum mail.
Old 25th July 2008, 05:39 AM   #193
lanchile07 is offline lanchile07  United States
lanchile07's Avatar
Lightbulb Have you try this Peter?
Peter,on your boards "LM3875".on the PS board.you use small caps 4.7/10uf 50v , and 1500uf caps on the "chip" board.
one time I was trying differents caps on the rectifier board and instead putting small caps on the rectifier board,I used Panasonic 1500uf 50v and Black Gate 1000uf 50v on the "chip" boards.and I do not kbow but I liked the sound better with the 1500uf caps on the bridge rectifier...I got better or more bass.can this be possible to leave the 1500uf caps on the rectifier board and the 1000uf BG on the "chip" boards?.
Thank you!
Old 25th July 2008, 06:13 AM   #194
mattjk is offline mattjk  United States
What is the best way to hook up an LED to one of the original rectifier boards?
does my wiring look OK, or should I get rid of all the braides and twists?
Old 25th July 2008, 06:33 AM   #195
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Have a read here .
With those lengths it's really down to aesthetics so you are the best judge of what you are happy with.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 26th July 2008, 01:08 AM   #196
Thanks Nuuk. I like the magnet wire idea, so I bought a roll. Then I got a stupid idea to rewire the amp, since I didn't like my first attempt.
So... now that it looks nicer, now my right channel does not work! I triple checked every connection with a meter, and also checked for cold solder joints. every pad on the right channel seems to match with the left. Did I kill the chip?
Old 26th July 2008, 02:15 AM   #197
Sparky OR is offline Sparky OR  United States
Try jumpering across the magnet wire, it's easy to not get all the insulation removed, alternatively, try jumpering from the good working input to the nonworking side. Just my 2c worth
Wish I'd studied this stuff with as much interest 30 years ago!
Old 26th July 2008, 02:20 AM   #198
thanks, Sparky. Yes, when I checked, I went from pad or rca connector, directly the to pads on the chip. I think I destroyed the chip somehow.
Old 26th July 2008, 02:45 AM   #199
What offset do you measure on each channel? Does the offset change when adjusting volume?
Old 26th July 2008, 02:46 AM   #200
Default Re: Have you try this Peter?
Sure, if it works better for you
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
