Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 18th February 2014, 02:59 PM   #1771
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Take the amp to his place and check how well it drives those speakers.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 18th February 2014, 04:47 PM   #1772
MagnumOpus is offline MagnumOpus  Norway
This amp is awesome. I have a pair of PSB Image B6 and they effing rock with this amp :-) It leaves nothing to be desired.
"Simplicity is the key to brilliance"
Old 18th February 2014, 05:57 PM   #1773
Joerytech is offline Joerytech  Netherlands
Did you ever try the LM4780 parallel amp on those kind of speakers? And if yes, what was your opinion?
My idea is that with those quiet heavy to drive speakers the capacitance of your amp design might have trouble.
Old 18th February 2014, 06:20 PM   #1774
Never tried on such speakers. If I see speakers like those, I always recommend bi-amping
www.audiosector.com
Old 25th March 2014, 04:11 PM   #1775
MrOfficer is offline MrOfficer  India
Dear All,
I've a center tapped EI core transformer with 18 0 18 secondaries.
Also, have rectifier PCB from audiosector - I searched on the forum and added 4 diodes and 3 jumpers to use with CT trafo.
The issues I've are that I'm getting a lot of variance in DC voltages.
Old 27th March 2014, 07:12 PM   #1776
Mark Whitney is offline Mark Whitney  Netherlands
Mark Whitney's Avatar
Where is the CT connected to the board? you need to connect + 0 -
Regards Mark.
Old 29th April 2014, 01:26 AM   #1777
Skwiddy is offline Skwiddy  United States
Welp...I just finished my temporary wire-up of my amp kit and I'm experiencing an odd issue. But let me take one step back first. When I first powered her up the wire coming out of V- over-heated and went up in smoke immediately. I believe the culprit was a stray ground wire touching the V- tab on the amp-board. I rectified this issue and haven't experienced the problem since. The problem I am experiencing is that the power output from the amplifier is definitely low. If I had to estimate I would guess it's sounds about half as powerful as it should be. I've tried it on several pairs of speakers and at full volume the sound is still about as loud as a normal conversation (there is no distortion)
Some measurements
(Oddly) Led tabs are outputting 33 volts dc
Pg - v - 33 volts dc
Pg + v + 33 DC
Speaker Terminals .013 DC
Thoughts? I'm stumped. Did I miss something while assembling? Did the shorted wires damage something?
Old 29th April 2014, 10:01 AM   #1778
barry.childs is offline barry.childs  United Kingdom
barry.childs's Avatar
Did it work OK between faults. Sounds to me like the short has blown the ICs.
Old 29th April 2014, 05:24 PM   #1779
It was playing music (at the same low volume) when it shorted out. If the IC's are blown would they still be capable of playing music distortion free?
Old 29th April 2014, 05:33 PM   #1780
Unless the IC's are Chinese! or you have a wrong value resistor somewhere.
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 09:07 AM
