Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 28th January 2014, 08:43 AM   #1731
tiglitosa's Avatar
Send a message via MSN to tiglitosa
Prevent thermal coupling with the floor? No i think the floor is coupled (or should be ) with the copper bar and the cable should pass either from the side which has a gap, or from a hole that should be opened in the copper.
As far as the top goes i agree with you.
Nick
Old 28th January 2014, 02:14 PM   #1732
The copper bar is bolted to the aluminum chassis, I don't think the heat-sink will reach temperatures that will melt the insulation of the cables.
What worries me tho is that the amp will get quiet warm even when not playing. Because the fuse in my multimeter is blown I can not measure the current.
Is there a "rest current" in the LM4780 like a class A amp.?
Joery
Old 28th January 2014, 03:28 PM   #1733
Btw, the DC voltage at output is 45 mV with volume at max and 4 mV with volume off
Old 28th January 2014, 05:29 PM   #1734
If it was maybe not clear but the design is that the bottom of the amp will float. The thickness of the toroid is bigger then the hight of the chassis so I will make stands on the chassis (one hole already made) to make the amp float and the chassis and copper bar will never touch the floor.
Old 29th January 2014, 08:34 AM   #1735
That tells me there is something wrong with the DC blocking input capacitor.
It could be leaking badly or fitted in the wrong location, or omitted.
Are your voltages DC?
i.e. 45mVdc and 4mVdc?
regards Andrew T.
Old 29th January 2014, 08:37 AM   #1736
If you can connect the copper bar to more of the thick aluminium case, the chip/s will run cooler.
What about the previous suggestion to run the 5 enameled wires THROUGH the copper bar and then Thermally connect the bar to the bolted down lid?
regards Andrew T.
Old 29th January 2014, 07:47 PM   #1737
The voltages are DC and what read in the previous comments the values are within limits.
I don't use input caps as they can make the sound quality worse.
I will leave the bottom of the amp open so if I need more heat dissipation i have to put a heat-sink on top of the amp.
This time I'm listening to the amp and must say it REALLY sounds great.
Peter together with the inventors of the LM4780 are great.
Thanks for that.
Greetz,
joery
Old 2nd February 2014, 04:49 PM   #1738
Weird enough I found out that the temp of the amp with no load is getting less after playing it for longer time?!
The neighbors are on holiday now so I pushed the amp to max for quiet some time and it performs well, its getting quiet warm but without any problems.
The combination of this amp with my speakers (Mission M52) is perfect.
On the pics you can see the stands its resting on, the power connection is not good yet, in the future I will make it nice.
Now I'm using a 6A slow fuse.
The coming days I will make the side panels from oak wood and I will replace the volume knob with a nice aluminum one.
All the bolts are from stainless steel.
Greetz,
Joery
Old 2nd February 2014, 05:18 PM   #1739
Now I'm using the output from my laptop and its actually not bad, In the future I will get a DAC to improve the sound quality.
I'm thinking about the dragonfly 1,2, it seems to preform good. Any comments about that?
Greetz,
Joery
Old 2nd February 2014, 05:28 PM   #1740
lanchile's Avatar
Greetz,
Joery
I do not see the power supply caps!
Am I blind?
Make it simple...Make it better!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 365 4th October 2011 08:19 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
