Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 15th November 2013, 10:48 PM   #1701
passive420 is offline passive420  United Kingdom
Originally Posted by stijn001 View Post
Thanks udaily, if you are so in the know, you could have just answered my question. But instead you chose to try and patronize me. That gives me the impression you are not a very pleasant person, prove me wrong. Please be assured that, I did "read" his comment very well, I Googled "rf filter calculator" and several other combinations and did not find what I was looking for, hence I asked the question. Don't believe me if that's your disposition, but donít blame me for it.
Guitar Pedals: R-C Filter Calculator
rc_simple_filter [Electron Coaxing Techniques & Notes]
First two on google with search term 'input roll off calculator' - you tried once and gave up?
udaily was not being condescending at all, that is not his way. He gave you the info you needed to help yourself. It's a better method of learning and teaching.
Old 16th November 2013, 12:01 AM   #1702
stijn001 is offline stijn001  Netherlands
stijn001's Avatar
Commercial Gainclone kit- building instructions
Nop, you are both wrong, I did try and look for an answer for about 20min, read a few pages and a wiki, found a couple of formula’s that I couldn't figure out the variables for etc.., but no calculator template.
I still don't see how I could have deducted from Andrew reply that 'input roll off calculator' was the search term to use. But hey I only have an MSc degree with honors from UCL & worked in ICT and telecommunication for 20 odd years, what would I know about finding information online.
Thanks anyway for answering my question. I hope I can return the favour sometime soon. It's easy when you know what to look for, isn't it? ;-)
On what ground did you assume I didn’t make any effort in the first place, to find an answer? And yes, since the answer to that question is “none” (ie you had no ground), imo you are both pretty condescending in your replies. If not, what would you consider “condescending” to mean? You have no idea whom you are addressing, right? Think about it.
Old 16th November 2013, 12:11 AM   #1703
nannoo is offline nannoo
Isn't it funny how people who use the arguement
"I've done [insert job title] for [xxx number] of years"
Seem to be the most objectionable?
- stijn, that's my nice way of saying bite your tongue, the only one looking a fool is you.
Old 16th November 2013, 09:06 AM   #1704
Originally Posted by AndrewT View Post
................The F-3dB (= 1 / 2 Pi R C) is usually set..................
RF filtering.
The series resistor and the following shunting resistor to Signal Ground form a low pass filter that attenuates the high frequencies............Listen and decide what suits you.
Start with F-3dB @~50kHz and see if that is audible. You may have to go as high as 300kHz to make this RF filter inaudible for you and your system.
Note there is a typing error: It should say "The series resistor and the following shunting capacitor to Signal Ground form a low pass filter.
.............Is there an online calculator or formula in which I can plug in the two resistor values to determen the RF cut-off frequency?
............ you could have just answered my question. ..............
Nop, you are both wrong, I did try and look for an answer..........................On what ground did you assume I didn’t make any effort in the first place, to find an answer?..............
Just read my reply.
I gave the standard "online calculator" for a single pole filter.
I gave you a start and end value for the filter F-3dB frequency.
I gave the the physical layout of the TWO components required to create that RF attenuating filter.
Just read the reply, instead of complaining.
regards Andrew T.
Old 16th November 2013, 02:02 PM   #1705
stijn001's Avatar
Andrew, Sorry if it appeared to you as if I was complaining about your post, that was never my intention and I’m very appreciative of you input and that of others in order to be able to build my first GC.
I merely responded to Udaily’s reply suggesting I hadn’t read your post and then responded to Passive420 for suggesting “I gave up”. Neither of which was the case.
I’m very surprised to be receive all these accusations in this thread, by merely posting a question, bizarre..
Old 26th November 2013, 04:29 PM   #1706
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Originally Posted by phil g View Post
This my first post so please forgive me if this is wrong place to ask this question.
I recently put together one of the LM4780 boards from Audiosector (to use in stereo for testing before finishing the whole kit).
I have tried three different potentiometers but there seems to be very little attenuation and certainly not all the way down to cut off.
The first two, a 10k and 20k (with a "B" designation I assume for "Linear") the attenuation is faint at best and not down to silence.
The third pot, is one retrieved from my old Technics amp with the makings of 100k Ohm B. This one does noticeably attenuate but not to cut off. To help make it clear what I am saying, the volume goes from loud to less loud.
Power is from 18v +- rails and rectifiers to 26.5v and 25v.
Thank you for any assistance on this question.
Phil
Hi Phil,
Pin 1 should go to signal ground on PCB and RCA jacks then pin 2 (wiper) to amplifier and pin 3 to preamp output.
See image below under volume control
Ciao!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 2nd December 2013, 12:52 AM   #1707
bobfig is offline bobfig  United States
Send a message via Yahoo to bobfig
hi guys haven't been on in a while but i have a question that i need help me with.
i would like to add a auto on/off circuit to the amp and need some way of implementing it.
i plan on using the amp for tv sound and would like to have it turn on and off with the tv. it will be using rca inputs.
Old 2nd December 2013, 09:43 AM   #1708
ESP has an auto turn ON/OFF circuit.
regards Andrew T.
Old 12th January 2014, 09:17 PM   #1709
Joerytech is offline Joerytech  Netherlands
Dear Peter D.,
I have received your LM4780 kit, it looks great.
In the first place I planned to build the kit in parallel configuration but because I have speakers that can be bi-amped (Mission M52) I'm considering to build the kit 2 x stereo.
My question is what you think will sound better.
I guess that in parallel mode the overall power output will be higher but if the sound quality in double stereo mode will be much better its something I can live with.
Also I probably can use a smaller toroid for powering the tweeters I guess.
Any info would be very welcome.
Greetz,
Joery
Old 13th January 2014, 05:37 PM   #1710
Because I want to continue I have ordered a 500VA 2x25V toroid transformer, I hope I can still use this one to power the 2 different configurations.
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 09:07 AM
