Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 9th May 2013, 12:02 PM   #1651
glenv6 is offline glenv6  United States
Originally Posted by Lightman View Post
If the LM3875 kit is built correctly, you shouldn't need a slow start circuit. If you "borrowed heavily from that design," what did you do different? Was it only the physical layout, or did you make any circuit changes from the kit specs?
I was referring to the physical layout with only one exception. I used one ground wire between PG on the rectifier board and the star ground point at the amps. I tied PG together on the rectifier board using 14ga solid core wire and soldered that single ground wire to the middle of that.
I turned the amp on and off many times and listed to it for hours before this happened. Looking my project over, I can't see anything I did wrong. It just seems like that huge toroidal transformer just surged when I turned it on that last time. It is a brand new transformer. Is it possible that the transformer is defective?
Any idea what could have been damaged? Should the caps and resistors be okay? My thought is to replace just the LM3875s and try again...
Old 9th May 2013, 12:05 PM   #1652
Originally Posted by AndrewT View Post
Beginners should never omit the "optional" stability and filtering components.
How about some detail. Which ones, and what would they have done to prevent this?
Old 10th May 2013, 11:25 AM   #1653
Lightman is offline Lightman  United States
You can measure the transformer's output, to see if it is functioning correctly, and measure the output of the rectifier board.
When you first assembled the amp, did you measure it's DC offset?
Old 10th May 2013, 11:11 PM   #1654
Hi Lightman, thanks for your reply... I measured the transformer's output on both sides AC and DC before I hooked it up to the amplifier for the first time. The voltages were matched and stable. I did not check the DC offset when I powered the amp up for the first time. I went straight to the speakers and supplied an input signal using an old Microsoft Zune I had laying around. The amp sounded great and I was very pleased! What did you have in mind with the DC offset?
The problem happened the next day after I moved the mains plug from the variac to a power strip and switched on the power supply with the amp hooked up. I assume the amp was working properly until then as it was quiet, cool, and sounded clear and good.
AndrewT suggested I use filters, so I explored this site a little more and found Nuuk's excellent article edited by AndrewT here: Building a Gainclone chip amp power supply.. My plan now is to add that "safety earth connection" circuit to the PSU, fuse the DC side and add the 10uf caps that came with the kit. I have new LM3875TFs on order for the amp, so I'll replace those and try again.
Thanks! -Glen
Old 14th May 2013, 03:06 AM   #1655
Default My Gainclone is alive and well!
Thanks to all the help on this forum, my gainclone is fixed. Turns out the amp was actually fine, it was the speakers that blew. The power supply was also fine, but it is now in an enclosure with proper grounds and it is quiet when turned on and off - no audible hums from the toroidal or pops in the speakers. Speaking of which, with a different set of speakers the amp sounds good again.
These new speakers are 4 ohm and the amp is running a little warm. I am hoping the amp runs cooler when I go to the 8 ohm full range speakers I am building.
Thanks again for the guidance.
-Glen
Old 23rd June 2013, 05:01 AM   #1656
servoG is offline servoG
Default ebay?
hello Peter
thanks for the nice thread..
i'd like to build an amp prefer on your LM3875 Premium Kit , did You sell it on ebay? please inform me,
many Thank
Old 28th June 2013, 03:18 PM   #1657
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
I do not sell on ebay, only directly from my website.
To order kits contact me through forum mail.
Old 30th June 2013, 05:55 PM   #1658
Even though I can't find any good quality component in my town, i decide to make my first gainclone... and yes it is good indeed the gainclone... thanks for this thread..
Old 19th August 2013, 09:41 PM   #1659
redal is offline redal
Smile Larger psu caps, where to fit?
I'm currently using the premium lm3876 kit on a plywood test board so I can try out different set up's before making an enclosure to suit. Currently I have the kit set us as standard (1500uf on amp, no PSU caps). I would like to try 3x 3300uf per rail, I have these soldered together so that only 2 legs need to fit through the PSU PCB. I don't know though if its OK to make it fit in the small pcb hole, or if there are alternative cap holes I can use. Any advice if its OK to use this capacitance and also how to fit greatly appreciated.
Cheers Andy
Old 19th August 2013, 09:43 PM   #1660
Hi I just wanted to clarify that I mean do the caps have to fit in the PSU holes meant for the low value caps supplied. I realise that my message was a bit unclear.
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
