Commercial Gainclone kit- building instructions - Page 163 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 29th August 2012, 02:14 PM   #1621
Originally Posted by Peter Daniel View Post
There's no common ground on rectifier boards (separate grounds for each rail which connect on amp board), so in your case just the wires from CHG for stargrounding.
Great, just to be safe . Still really loving the amp but my new speakers need some more juice. Thanks for answering.
Old 2nd September 2012, 12:42 PM   #1622
I've completed one of your builds, Peter - it sounds beautiful. Thank you!
Unfortunately, I'm getting loud pops when I turn on/off a (very cheap) desk lamp. Obviously I should just get rid of/move the lamp, but I'd like to do something about mains filtering.
I remember Marantz offered a power amplifier with a (large, expensive) battery partner. Instead of batteries, what about using a bank of supercaps? Can we completely separate the amp from the mains like that?
I'm also getting phone signal noise - I'm going to put together some shielded interconnects - so if there's something else people would suggest? I've seen some questions on here recently but I must have missed a solution if there was one...
Old 5th September 2012, 01:42 PM   #1623
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Try that: Commercial Gainclone kit- building instructions
Bank of supercaps instead of batteries won't work here.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 6th September 2012, 05:39 PM   #1624
jimchan is offline jimchan  Norway
Default Low sensitivity speaker
Hi Peter, have the amp up and running, impressed by the clear sound but not singing as it should.
Dc offset is good, less than 10mv and no hum from the speakers even though not using exact star ground as recommended.
The bass is crisp, but the midrange and treble is distinctly lacking. Have tried with iPad and the Dac, and similar impression. existing HarmonKardon amp gives a full sound but not the clarity.
I note now my speaker sensitivity is 86db, 8 Ohm. Could this explain?
Br, Jim.
Old 7th September 2012, 08:14 AM   #1625
Is the treble driver working?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 7th September 2012, 08:56 AM   #1626
good question, but yes. Ribbon tweeter is giving a slightly harsh response. bass OK, but underpowered. Mid range lacking.
230VA transformer, single rectifier to two amp boards.
I will also double check the correct component placing/sizing, but I have checked all this before.
Should I try with large capacitors (snubber) ?
Old 7th September 2012, 05:02 PM   #1627
Jepp....10.000 uF caps and snubber has given the amp what it needs to drive the speakers.
Sounds nice, and certainly different to the HK...
Old 8th September 2012, 02:00 AM   #1628
Default Bridged LM4780 Questions
I am building the LM4780 in bridged configuration with one transformer and rectifier board and two bridged amps and had a few questions. If my questions have already been covered, I apologize but I've looked and cannot find specific answers.
1. For star grounding, the OG on the amp boards are tied together with the middle of this connection grounded to the metal case enclosure. The PG+ and PG- on rectifier board are connected to this chassis ground as well. Is there anything connected to PG+ and PG- terminals on the amp boards?
2. Is the speaker output connected through both "OUT"s on the amp board? If so what is the polarity of each "OUT"?
3. Is the input connected to the amp board on both "IN"s? If so, what is the polarity of each?
Thanks in advance for any help.
Old 8th September 2012, 04:39 PM   #1629
Bridged configuration has been explained here (same as stereo setup): AudioSector-chip amp kits, dacs, chassis
www.audiosector.com
Old 8th September 2012, 06:21 PM   #1630
Peter, thanks for the quick response. I've looked at Post#246 and the LM4780 Amplifier Schematic but I'm still not 100% sure how to connect the inputs and outputs for bridged configuration.
Is this right:
My input signal + wire goes to both "IN"s on amp board and my input signal - wire goes to both "SG"s on amp board?
Both "OUT"s from amp board go to speaker + terminal and "OG" on amp board goes to speaker - terminal?
Thank you for your time.
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
Copyright ©1999-2017 diyAudio
