Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 24th April 2012, 02:22 PM   #1591
battery life.
Old 25th April 2012, 02:02 PM   #1592
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I've been running one of my amps from batteries for over a year. They were 6x 12V Panasonic cells providing approx +/-39V . Didn't observe any long term problems.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th April 2012, 02:22 PM   #1593
Mr Daniels, I have recently bought and assembled your LM3875 kit, chassis is in the making and I am trying to decide to give my amp a volume pot or a buffered volume control, what do you reckon?
I allready have a tiny opamp volume buffer from SKA Audio, needing only a psu for it, or simply put in a 50k Alps? I really don't want to spend too much money on the pot. If it sounds good its good enough
Old 25th April 2012, 02:31 PM   #1594
A potentiometer mounted directly at amp's input works best, I usually recommend 25K or 10K.
www.audiosector.com
Old 25th April 2012, 06:37 PM   #1595
Thank you.
Old 26th April 2012, 02:13 AM   #1596
TomTerrific's Avatar
Peter, So how did the amp sound when powered by batteries? I can't imagine the battery power supply would make any appreciable improvement in sound quality, (My amp sounds terrific) but I can imagine the "flavor" of the sound could change somewhat, maybe making it even more agreeable. Batteries don't cost that much. Is this worth pursuing?
DIY "Career" - TriTrix Speakers, "Repackaged" Tripath T Amp, Stereo LM3886, B1 Buffer, Dual Mono LM3875, Boozhound Labs JFET Phono Pre // Trust me, I'm a musician.
Old 27th April 2012, 03:26 AM   #1597
Default Lower noise floor?
I'm guessing that battery power will lower the noise floor. I'll report back to the thread when I've cot mine up and running. I am going to try an Aikido LV tube preamp stage in front of the chip amp. Planning to run both it and the amp on a 26.5VDC LiFePO4 pack. I just can't imagine how rectified power can possibly be as clean as pure battery power. I've heard arguments on both sides, but ultimately, you've got to try it yourself to find out.
I got on this battery kick when I built a linear power supply for my Squeezebox Touch. Amazing difference, even when using the digital outputs, and it got me thinking. Next, I tried running my tube preamp (an Elekit TU-875), which came with a switching wall wart power supply, on a LiFePO4 battery pack. The improvement was staggering. I was honestly not prepared for such an improvement.
Old 28th April 2012, 07:06 AM   #1598
bobfig is offline bobfig  United States
Send a message via Yahoo to bobfig
im in the process of building one of these and im a little stuck. i am wondering if i need isolated rca jacks when mounting on a aluminum enclosure or would regular ones without the isolation washers do. i have a pair of uninsulated from a previous project that i didn't need them for so i don't want to have to order new ones if i don't have to.
Old 28th April 2012, 07:12 AM   #1599
Marra is offline Marra  United Kingdom
You need to use isolated ones.
Old 28th April 2012, 08:29 AM   #1600
K
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 365 4th October 2011 08:19 AM
Copyright ©1999-2013 diyAudio
