| Audio Sector Kits & PC boards from AudioSector |
#1551 | ||
i'll try your recommendation on the BG STD first, leave the BG F in place, and see how it sounds. thanks! will report back soon Last edited by idjoel2000; 12th March 2012 at 05:15 PM. |
#1552 |
Electrons are yellow and more is better!
Have you ruled out your signal source? How does it sound with an another amp? The LM38xx is pretty good if you do it right.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#1553 |
#1554 | |
The LM3875 datasheet gives 3.16A peak output current at 40W and 8Ohm loads. I could verify myself that, even if my chipamp outperforms (in my view) my commercial YBA amp, the YBA provides a much higher sound pressure level: it is rated similarly 50W at 8 Ohm (but 90W at 4Ohm). Renato |
#1555 | |
btw i'm using headphone, not speaker (very heavy to drive, like AKG K1000. i need to crank the volume od the GC to 1-2 o'clock to get to convenient listening level) |
#1556 |
i changed the caps in rectifier board to BG STD now, it sounds much more open!! but the low bass quantity is still less than before. i guess i will just let it run for a while before making any further judgments
after changing the caps, i measured the dc offset on the output of both binding posts. it reads 90 & 94mV on the left and right channel respectively when i set the potentiometer to maximum. is this normal? Last edited by idjoel2000; 13th March 2012 at 11:13 AM. |
#1557 |
That's not right I think. Those headphones have 120ohm impedance and 74dB/volt sensitivity. You should only need a couple of watts to drive them to full output.
#1558 |
#1559 |
#1560 |
Check your posts before abandoning them.
| Commercial complete Gainclone kit for a beginner? | gychang | Chip Amps | 365 | 4th October 2011 08:19 AM |
