| Audio Sector Kits & PC boards from AudioSector |
#1541 |
Passive Aggressive
You didn't do anything wrong. You seemed to be wondering how to improve it. These are three big changes to the amps sound. New cap size is easy. Resistor replacers take maybe a half hour and a new supply maybe an hour or so. Try the BrianGT Aleph power supply. Cheap board and great results.
CRC means caps followed by a small resistor followed by more caps.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#1542 |
i don't use input resistor at all, instead, i use BG NX 22uF/6.3V (i've tried shorting this input resistor, no difference compared to BG NX installed. so i just left them there).
your resistor replacer works as an input resistor with LDR as the medium, i take it? if it is so, going resistor-less should be better i think *just my 2 cents. please enlighten me if i'm wrong* i still haven't put the BG STD 1000uF yet, i don't know how big of an improvement i could expect going from fc 1500uF to BG STD 1000uF peter daniel, would you care to chime in? |
#1543 |
Passive Aggressive
I would bet no resistor would be better for sound but its a safety measure to have resistance there. However I cap in the signal is a safety issue I leave out for Sonics. I mean replace the big caps near the chip with 100uf. Not 1000 or 1500. See diyaudioprojects.com for support on my 100uf suggestion.
#1544 |
maybe you read in some of the previous posts I am now happily listening to music by an Audiosector premium kit in a gainclone amp with single stereo input. I am going to build an input selector. Attached you can find a drawing of the wiring I intend to use for the signal grounds (input and output). Is this wiring correct or can I improve it in particular to reduce the risk of ground loops? Thank you Renato |
#1545 |
Passive Aggressive
looks right
#1546 | |
I couldn't find any better resistors for a premium version than Caddocks and Rikens. Rikens are not available any longer and closest replacement is Kiwame, which sounds quite similar. You mentioning tantalums and IME those resistors were quite different (comparing to Rikens) What size BG F cap are you using on amp board? If you want to get close to Patek, I would strongly suggest BG STD 1000uF in rectifier section and 100uF caps on the amp boards. I'm not sure about BG F here, as those are different than BG N I'm using myself, but Panasonics FC are pretty close in tonal signature to BG N's. I understand that you are using BG NX 22uF/6.3V for input coupling. If you make sure that your sources do not produce any DC offset, you may omit that cap as well. I also don't use R1 resistor.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#1547 |
#1548 | |
Concerning my amp, Audiosector premium kit with standard Panasonic caps, I am very satisfied and I found an incredible improvement in sound when compared with my commercial YBA Integrč integrated amp (respected in the audio magazine world and class A on Stereophile during 90s). Finally I got the transparent and natural sound from my Jordan JX92 drivers I heard at audio shows but never realized at my home. I did not realize how important was the amp for the final result. A main difference between our amp is that, if I well understood, you are using 1 trafo 225VA while I am using a dual mono configuration with 2 trafos 160VA 25VAC. The only limitation I clearly see of this chipamp is the possible lack of sufficient power in case of low speaker impedence and/or efficiency. Renato |
#1549 | ||
yes, i do have BG STD 1000UF as per your suggestion. but i haven't installed it yet, now it's still panasonic fc 1500uF sitting on the rectifier board in the amp board, i use 100uF BG F since panasonic fc is a very mediocre caps in my opinion, so i went with the BG F (i have good experiences with BG F) so you suggest me to use panasonic fc 100uF on the amp board, and BG STD 1000uF on the rectifier board? regarding the fuse, will it bring any improvement if i change the 2A slow blow fuse to 3A? |
#1550 |
I wouldn't expect any difference with fuses and yes, I would suggest to start with Kiwame for gain setting, BG STD 1000uF at rectifiers and Panasonic FC 100uF on amp board, and then experimenting with different components, if needed.
| Commercial complete Gainclone kit for a beginner? | gychang | Chip Amps | 365 | 4th October 2011 08:19 AM |
