Commercial Gainclone kit- building instructions - Page 153 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 24th January 2012, 11:07 PM   #1521
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Usually, 0.1 -0.2R is recommended. If you play at normal levels. 0.47 should work too.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th January 2012, 06:14 PM   #1522
ss007 is offline ss007  United States
I got the wiring of my power umbilical wrong and sent reversed voltage to the chips. They smoked in about 2 seconds. I installed 2 new chips fix the umbilical and it powered up fine.
I have .106 dc on both channels. It's a bit higher than the last amp i built. only difference between the two is I'm using an input resistor on the new one.
I'm wondering if the capacitors could have been damaged by having reverse polarity for a couple seconds. If so, could that cause the dc offset to be higher?
Old 25th January 2012, 07:06 PM   #1523
cure for mistakes like that.
fit a 1n400x diode across one of the main electrolytic decoupling caps mounted on the PCB and fit another to the other half of the dual supply.
You can also fit a 1n400x from each power rail to the output.
These 4 diodes save a lot of damage if the PSU is ever swapped around and can help with IV protected amplifiers driving dynamic (VC) speakers.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th January 2012, 01:20 PM   #1524
dirkwright's Avatar
Just finished my Audio Sector kit last night and it's working wonderfully. It's a dual mono arrangement with the Twisted Pear USB receiver/DAC as the input device. I use it with my computer. I put so much capacitance in the power supply that I can flip off the power and it still plays for a while!
Old 26th January 2012, 04:08 PM   #1525
Thanks Andrew! Great tip.
I'm still curious about the reverse voltages damaging capacitors. Is that a possibility after 2-3 seconds?
Old 26th January 2012, 06:29 PM   #1526
Damage is very possible.
Remove at least one leg of each and reform them, noting how the reforming current varies over 24hrs.
regards Andrew T.
Old 26th January 2012, 06:38 PM   #1527
Electrons are yellow and more is better!
peranders's Avatar
A couple of seconds won't probably create any damage, just use them. If the cap is rounded at the top, then you should react.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 26th January 2012, 07:30 PM   #1528
They look fine. Didn't get hot or do anything weird.
Old 26th January 2012, 11:33 PM   #1529
As it was explained here: Commercial Gainclone kit- building instructions the actual offset will depend on a particular chip, and varies sometimes significantly, from sample to sample.
The caps are fine.
www.audiosector.com
Old 26th January 2012, 11:44 PM   #1530
Thanks Peter
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
Copyright ©1999-2017 diyAudio
