Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 18th January 2012, 05:26 PM   #1511
Marra is online now Marra  United Kingdom
Commercial Gainclone kit- building instructions
I take you recommend an input cap Andrew?
Old 18th January 2012, 07:43 PM   #1512
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Why would anybody suggest input caps if those voltages are only with attenuator and without any source connected yet? The input caps are needed in case the source producing the offset. I'm not familiar with LDR, but I don't think it's adding any offset?
Is it passable? How much offset do you read at normal listening levels? If you won't be exceeding 80mV or so, I would say it is passable. Otherwise you need NFB cap, not an input cap.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 18th January 2012, 08:01 PM   #1513
Thanks for the response Peter. I connected the integrated GainClone to my cd player and a pair of 4" Tandy speakers and it plays music; spent the last hour listening to J J Cale live. I never thought to check the dc when listening; I take it thats what you meant? I'll listen again tomorrow.
Old 18th January 2012, 08:37 PM   #1514
Yes, check the offset again with the source connected
www.audiosector.com
Old 19th January 2012, 07:08 PM   #1515
A couple of photo's. I won't get chance to listen until tomorrow and check offset dc.
Old 20th January 2012, 11:08 AM   #1516
Tried it out this morning and with the cd player and an old pair of speakers connected dc offset maxs out at 38mv on one channel and 46mv on the other. I've been listening to music for the past two hours and nothing overheats and sounds good too even through a crappy pair of 4" drivers.
Old 20th January 2012, 11:22 AM   #1517
R.I.P.
What is the assembly just below the in/out RCAs?
regards Andrew T.
Old 20th January 2012, 03:06 PM   #1518
Originally Posted by Marra View Post
...dc offset maxs out at 38mv on one channel and 46mv on the other.
Those offset values are perfectly fine.
www.audiosector.com
Old 20th January 2012, 03:56 PM   #1519
Thats the Optivol LDR volume control[pcb's courtesy of dvbprojekt; unfortunately no longer available] with a Bib reg to its left.
Old 24th January 2012, 07:12 PM   #1520
Would 0.47R be ok for the output resistors?
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
