Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 21st June 2008, 01:30 PM   #141
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
You do have a source selector though, otherwise how do you switch between sources?
If so, turn selector to turntable first and then switch off the CD
The thermistor will not help here, it's merely there to isolate circuit ground from chassis ground and the idea of using it came from First Watt amps.
To order kits contact me through forum mail.
Old 21st June 2008, 02:18 PM   #142
carawu is offline carawu
Jan,
try 300pF PS between Pin 7 & 8.
Old 21st June 2008, 03:33 PM   #143
tangen is offline tangen  Norway
Originally posted by carawu
Jan,
Thanks guys!
One more question to Carawu: forgive me my little knowledge, but what does PS and pin 7 and 8 stands for?
best wishes
jan ove
Old 21st June 2008, 04:14 PM   #144
PS could stand for polystyrene cap: http://www.diyaudio.com/forums/showt...22#post1516522
Old 21st June 2008, 04:30 PM   #145
Thanks again. I will try this as soon as I got some spare time My wife wants me to paint the fence in the garden :
best
jan ove
Old 21st June 2008, 05:19 PM   #146
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
I'm rather lazy, you see
Karma!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 5th July 2008, 10:29 AM   #147
AlanElsdon is offline AlanElsdon  England
Default thumper here
Peter,
Thanks for the direct, this is what I intend to do but with all four amplifiers on each side. One slight problem is getting hold of thermistor CL-60 - they are not sold here in the UK! Farnell will take the order but I have to then pay a premium ($30) for them ordering them from the states! So until I can get hold of some I will use your original method of connecting to the groung earth with a 10R resistor.
Alan
Old 5th July 2008, 02:09 PM   #148
Vautrin is offline Vautrin  United States
Thanks for this superb tutorial, Peter, but color me dense...
I can't figure out where R1 is (or goes). Is there a posted photograph showing either the wire, resistor, or cap soldered in place? I have four resistors on my board/s, can see the position for Rz(obel), and can see R1 in the diagram (Post #3).
I have a PSU question, too. I chose to power two amp boards in stereo config with one Avel 250VA 25V-25V toroid in a separate cabinet. Is it best to also house the rectifier board with the toroid? Or should I put it close to the amp boards as demonstrated here? What are the pros/cons of each?
Also, if I house the rectifier board with the toroid, how many wires do I need in my umbilical (at least four, of course)? I see your elegant Patek arrangement showing only four wires in two photos, whereas the example integrated amp in this tutorial shows two grounds to the star and four other wires to the boards.
Lastly: if I add two fast-blow fuses (for initial testing), do I still need the light bulb? (I've tested the PSU with the LED. It glows. Nothing smokes.)
David Barnett in SW FL
Old 5th July 2008, 02:13 PM   #149
Where would be those two fast blow fuses installed?
Old 5th July 2008, 02:15 PM   #150
R1 is the first ressitor on the left in this picture: http://www.diyaudio.com/forums/attac...amp=1210697477
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
