Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 14th February 2011, 05:31 PM   #1381
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Bulb tester was described here: Commercial Gainclone kit- building instructions
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 20th February 2011, 02:22 PM   #1382
deepblue2010 is offline deepblue2010  Luxembourg
Hi Peter,
After a week could not touch the board, I can continue my project this weekend.
1. The rectifier passed the test. Without the cap, the output between V and PG for both rails is 36.2VDC. You said it should be approximately +-20Vdc without cap, and 30+ with cap.
Is it too high on my board? I used toroid 230v-25v x 2.
Then I finished soldering parts as in the first picture.
2. I connect the PS to two amp boards and used star ground. For testing, I soldered the star ground to the ground line of home electric net. An ALPS 50k is used for volume.
Now is the result of dry test with no load:
- In the first time turn on, volume is completely down, left channel offset was -25mV and right channel offset was about +32mV! I turned the volume up, left channel went up to -70mV and right channel went to -27mV. Is it abnormal?
- Turn the amp off and no speaker connect, I could see the offset jumped to 4.36V.
- I let the amp run with no input and no output for more than 3 hours, the left channel offset values is the same as the first test (-25mV with min volume and -70mV with max volume). However, the right channel, something strange (i think) happened: with the volume set completely down, the offset value was changing gradually from +32mV to -14mV and the offset when volume was set maximum was also adjusted accordingly and the last value I could measure was -53mV or so.
I don't understand this. Could you please advise?
By the way, one of the 1500uF cap has a little distortion on its cover when I first checked parts from the delivered package. I thought it is OK anyway and continue as you can see. However, the above phenomenon is accidently occuring to the board with that cap on.
Is it true that the distorted cap (just a little) does not work properly?
For your reference, the 2nd, 3rd, 4th and 5th pics were captured the offset values (volume set minimum and maximum respectively) of right and left channel during test.
3. I left the amp run with no input and output load for more than 3 hours. Is it equivalent to running the amp with in/out load in the same amount of time?
Many Thanks.
Old 20th February 2011, 02:53 PM   #1383
My voltage suggestions were for 22V transformer, what you are getting with your 25V unit is perfectly fine. Please also note that voltage variation will depend on output from the wall and it may be off 10% off from nominal rating and on regulation margin of transformer (the voltages are listed at full load, which you won't see with that amp)
This is perfectly normal and that's what I was trying to point out in post here: Commercial Gainclone kit- building instructions
The offset will depend on a particular chip and is subject to shunt resistance (22k) at amp's input. Adding pot in parallel with that resistance will affect combined shunt resistance value and that's why you see those changes when pot turning. When you add coupling cap between pot and the amp, the shunt resistance value is not affected by pot rotation, but since it's always 22k the offset will be also highest, that's why I said that adding coupling cap may actually increase your offset (-70mV vs -25mV for left channel, with a right channel there is no so much difference as offset balances nicely through 0 point).
This is also true for amp with no pot and low output impedance source connected. You will always see a drop in DC offset when connecting source, you won't see that effect with coupling cap in place. BTW, I measured offsets on 47Labs Gaincard and they were approx 80mV.
4.36V at shut down is normal with no load, when speakers are connected, it doesn't happen.
www.audiosector.com
Old 20th February 2011, 02:58 PM   #1384
The cap has nothing to do with that, and slight blemish does not affect anything here.
I can't comment on point 3; it could be the same or it might be not, but it's best to burn in the amp with signal and the load.
www.audiosector.com
Old 20th February 2011, 05:33 PM   #1385
tiglitosa is offline tiglitosa  Greece
tiglitosa's Avatar
Send a message via MSN to tiglitosa
Default panasonic caps
Hi Peter
Can you tell me the digeykey part number of the panasonic 1500uF caps?
Thank you
Nick
Old 20th February 2011, 06:07 PM   #1386
It is P10334-ND
www.audiosector.com
Old 20th February 2011, 06:09 PM   #1387
tiglitosa's Avatar
excellent, i blew the off and i needed new hehe
Thanx
Nick
Old 20th February 2011, 11:11 PM   #1388
It's very clear. Now I can understand what and why you did the experiments.
Thank you so much.
HT
Old 22nd February 2011, 03:09 AM   #1389
bbm3 is offline bbm3  United States
Peter,
Today I built one of your LM3875 kits.
So elegantly simple.
Sounds so good.
I love it.
Thanks for sharing.
BB
Old 25th February 2011, 01:51 AM   #1390
Default My GC is working and new questions
Peter,
I finished all soldering work and test and could not wait to check the amp till this weekend. So yesterday night, I connected the amp to a Jamo rear surround (1 cone - 8ohm) borrowed from landlord just for testing. It worked, the amp is working now, two channels.
I could feel the clarity of high frequencies but could not test med and bass. I think just because the speaker has only 1 cone and cannot cover all freq. "Burning" it for about 2 hours while enjoying music from the system. That's an amazing feeling having my first diy audio working.
I can say that the sounds is so good, very clear and really really nice to my ears. I particularly love the vocal from Eva Cassidy - Fields of Gold, Diana Krall and Norah Jones. I could feel the clear crack in the voice of Tom Waits in Big in Japan. The flute in symphony by Aaron Copland also very clear and smooth.
More than that, the amp makes no hum, completely quiet and no "thump" when turning power switch on/off (I still use the switch on power cord in this test) and plug in/out the input cable from my computer to the amp. It definetely beats my current cheapo computer speaker Altec Lansing 2.1.
That's a great work, Peter ! I am very happy ! Thank you so much for very detailed instruction and also thanks other people for Q&As here. I learned a lot.
My new questions, Peter.
1. I measured the voltage between PG and V outputs of rectifier. Without the caps, the voltage is 36.15Vdc. As far as I know, with the caps on rectifier, the voltage will be more than 36Vdc, right? Will it be OK using those caps. What and how will the performance be affected with/without the supplied caps (10uF) on rectifier?
2. In post #50 (Commercial Gainclone kit- building instructions), you commented "Without R1 the sound will be more neutral and transparent, especially with Premium kit.
I supply that resistor "just in case", to provide some isolation for amp's input.
I am using the Premium kit with R1 onboard. Is that the reason that the amp makes no hump and thump when I turn main power on/off and plug input cable in/out the computer soundcard?
I will try the amp without R1 later, with proper speakers, in order to look for better listening.
3. I know that not just the amp but the speakers also make a greate enjoyment. Pity that I don't have a good speakers for testing.
Would you have suggestion to select a good bookshelf speaker?
What do I need to make the GC amp for a 2.1 speaker system?
My Altec Lansing 2.1 is 8ohm with built-in amp. Is there anyway to use GC amp for the speakers?
Many thanks.
HT
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
Copyright ©1999-2017 diyAudio
