Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 4th November 2010, 10:02 PM   #1301
jonners is offline jonners  United Kingdom
jonners's Avatar
No worries, I've now found a larger case that will give me around 8cm between chips and toroid, so I'll probably go with that.
John
Old 4th November 2010, 10:22 PM   #1302
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Even 4cm from transformer is fine.
To order kits contact me through forum mail.
Old 4th November 2010, 11:06 PM   #1303
jonners's Avatar
Thanks for your reply, Peter.
John
Old 7th November 2010, 08:07 AM   #1304
gille is offline gille  Denmark
Hi
I built a couple of these last year. I experience a high pop in the speakers when I turn off the gainclones. Any information about this?
Old 12th November 2010, 09:05 PM   #1305
captainobvious is offline captainobvious  United States
captainobvious's Avatar
Send a message via AIM to captainobvious
Unfortunately, we arent able to search just this thread So Im about to ask a question that has probably been asked a few times before in this thread (Sorry! It will take a week to read through the whole thing)
I have a ground loop hum issue.
I built the LM4780 4 channel version wth two amp boards. ( 2 channels off each board and one transformer).I followed the directions and did the star ground. My RCA's are isolated from the chassis with plastic isolation washers. When I have my PC connected via RCA as a source to the amp, I get alot of hum, even at low volumes. If I disconect the power cord from the PC and run just off the battery the hum goes away instantly. Is there a modification I can make to the amp to eliminate this issue?
Sounds fantastc when its not humming!
Old 12th November 2010, 09:18 PM   #1306
Did you use both rectifier boards or just one as recommended?
Is your star ground as described here: Commercial Gainclone kit- building instructions
Old 12th November 2010, 09:27 PM   #1307
Yessir, one rectifier board as you suggested. And yes to the star ground model as well.
Old 12th November 2010, 11:07 PM   #1308
udailey is offline udailey  United States
Passive Aggressive
Okay, with all due kindness but a bit of hilarity I have to say
"Hey CaptainObvious, in fact you can search this thread. Up at the top where it says "search this thread."
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 13th November 2010, 02:02 PM   #1309
Thats odd. Yesterday all I saw up there was thread tools, today I see the search option and the thread rating...
Old 13th November 2010, 05:13 PM   #1310
jonners's Avatar
I think you have to be logged in for those to appear.
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
