Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 25th August 2010, 03:32 PM   #1221
pmchoong is offline pmchoong  Malaysia
pmchoong's Avatar
i only have this preamp now.....b1 buffer still needs to connect all parts and still no chassis yet.
Old 25th August 2010, 03:44 PM   #1222
pmchoong's Avatar
if i turn the volume down to zero and put my ears close to the speaker, i can hear music (from the tuner) beyond the buzzing sound...very strange
Old 25th August 2010, 03:53 PM   #1223
pmchoong's Avatar
buzzing is audible when you put your ears very close to the speaker....say about 2-3inch from the speaker and listen hard
Old 25th August 2010, 04:00 PM   #1224
diabloid is offline diabloid  United Kingdom
Buzzing from ac mains is expected with diode bridge and small filter caps, but once amplifier is connected to load it is not noticeable, when music plays. The only way to make it totally silent: 1. to use car batteries 2. to use regulated power supply.
Old 25th August 2010, 04:14 PM   #1225
pmchoong's Avatar
you mean
1)the buzzing sound will always be there if you use mains
2)no way to completely eliminate the buzzing unless you use the two options as suggest by you
but i read many people said (in this forum) that it was completely silent....no back ground noise
Old 25th August 2010, 04:17 PM   #1226
koogar is offline koogar  United Kingdom
koogar's Avatar
Does the buzzing stop if you lift the earth ?
Old 25th August 2010, 04:19 PM   #1227
R.I.P.
Originally Posted by diabloid View Post
once amplifier is connected to load it is not noticeable, The only way to make it totally silent: 1. to use car batteries 2. to use regulated power supply.
no.
Correct wiring and routing of wiring can give a silent power amp output.
regards Andrew T.
Old 25th August 2010, 04:19 PM   #1228
pmchoong's Avatar
how do you 'lift the earth'?
Old 25th August 2010, 04:22 PM   #1229
pmchoong's Avatar
Originally Posted by AndrewT View Post
no.
I have a very small chassis (hey...it was free, so no complain) and wires run besides the transformer. Please see picture
Old 25th August 2010, 04:31 PM   #1230
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
hi
are they from alumunium ?
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
