Commercial Gainclone kit- building instructions - Page 122 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 25th August 2010, 02:34 PM   #1211
pmchoong's Avatar
this is how i hook up everything......at present i am using one transformer to test both mono block channel.....the other transformer is still wip
Old 25th August 2010, 02:38 PM   #1212
pmchoong's Avatar
should i resolder the chip again?
Old 25th August 2010, 02:46 PM   #1213
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
If the buzzing can be detected with both channels connected separately, it's probably something else than bad soldering. It's quite unusual to get a hum with a single mono channel, unless the buzzing comes from your source?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th August 2010, 02:46 PM   #1214
pmchoong's Avatar
dc offset at 14.5mv with volume down but when volume turn up to 9 o'clock....dc offset is at 7.9mv....and when turn all the way up, dc offset at 300mv!
Old 25th August 2010, 02:49 PM   #1215
Without input coupling cap it's normal for offset to change up to 80mV or so.
300mV high could indicate that your source produces some offset as well.
www.audiosector.com
Old 25th August 2010, 02:55 PM   #1216
pmchoong's Avatar
it change to 7.9 (7 point 9)mv....not 79mv
Old 25th August 2010, 03:18 PM   #1217
pmchoong's Avatar
Originally Posted by Peter Daniel View Post
.... It's quite unusual to get a hum with a single mono channel, unless the buzzing comes from your source?
Stupid me....i forgot to turn the preamp source selector to tuner.....sorry everybody.....i feel very bad making you guys putting on your thinking cap to discover something i did stupid......now i got sound coming out from the speaker except the buzzing sound still exist...errrrrg...how the heck can i get rid of this buzz sound..it is very low and audible on close up......on both mono....same issue....how come? When i switch off the preamp, i still can hear this buzz from the speaker
Old 25th August 2010, 03:21 PM   #1218
If your source is tuner it's quitepossible buzzing comes from it. Do you get hum with volume all way down?
www.audiosector.com
Old 25th August 2010, 03:24 PM   #1219
pmchoong's Avatar
sounds good except for the buzzz...is it the transformer?
Old 25th August 2010, 03:25 PM   #1220
pmchoong's Avatar
yes....even if i turn off the preamp
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
Copyright ©1999-2017 diyAudio
