Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 25th August 2010, 12:16 PM   #1201
R.I.P.
I agree with Ud, remove chassis and layout the modules in a string, Mains at one end, then through the stages, to the input RCA at the other end.
Couple up and power up.
Is hum or buzz heard and/or measured.
Connect as a stereo pair. Test again, measuring the hum or buzz.
Remove the source leaving the RCAs unterminated.
Does the noise measure worse?
Now that you know what the system can achieve, start casing it up.
regards Andrew T.
Old 25th August 2010, 12:16 PM   #1202
pmchoong is offline pmchoong  Malaysia
pmchoong's Avatar
Originally Posted by udailey View Post
pmchoong, please make sure of these things:
1: As with the other gentleman your rcas should be insulated from the chassis. (its okay that they touch but it can cause ground loops which will buzz)
2: Do you have signal going to signal or do you have signal and ground switched around on your RCA plugs?
3: this buzzing can be caused by bad solder joints and if you made your own RCA cable there could be bad joints there or you could have bad joints in your input RCA jacks on your chassis.
4: solder joints could be bad at signal input to amp boards.
....That covers bad solder joints I guess. .... Wiggle the wires, touch the volume pot, touch the heatsink. Does the hum/buzz change when you do this?
Uriah
1) I have removed the rca from the chassis
2) Signal wire going to signal and grd wire going to ground
3) will check
4) will check
Thanks. Yes...wiggle the wires (that connects the rca and the board) and the buzz gets real loud....depending on how gentle or rough you wiggle them.
Will check again on solder.
Old 25th August 2010, 12:45 PM   #1203
pmchoong's Avatar
do i need to connect the 'chg' from main board to the chassis? Did this and resolder the joints, now the buzz is less but when connect to preamp, the output from source (my radio for testing) is very faint.
Old 25th August 2010, 12:47 PM   #1204
pmchoong's Avatar
"With dual mono version though, you will run a ground wire from CHG (chassis ground hook up point on each amp board) to chassis." post 168 from peter
Old 25th August 2010, 01:31 PM   #1205
pmchoong's Avatar
connected the cg
hg to the chassis...resoldered joints....still buzz when connect to preamp. sound from radio is very faint.
Old 25th August 2010, 01:37 PM   #1206
pmchoong's Avatar
now when i wiggle the rca wires....the buzz remains at same loudness. the buzzing sound is much lower now...but constant....sound from the radio is at background...can be heard when turn preamp volume to maximum.
Old 25th August 2010, 01:43 PM   #1207
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Are you using dual mono or stereo setup? Do you have buzz with only a single channel connected to PS?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th August 2010, 01:44 PM   #1208
pmchoong's Avatar
i am using dual mono....buzz in both mono
Old 25th August 2010, 02:04 PM   #1209
Is there buzzing when signal connected to one channel only (the other channel completely disconnected)?
www.audiosector.com
Old 25th August 2010, 02:10 PM   #1210
pmchoong's Avatar
ehhh....i use the same transformer to test each individually
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
