Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 20th July 2010, 09:35 PM   #1181
northernsky is offline northernsky  Italy
The offset does not vary by pot setting; but I put 4.7microF caps at input and I read somewhere that in this way offset does not change.
But now is late in the night in Italy, I'll try to connect speakers tomorrow,
thank you Peter
Renato
Old 20th July 2010, 09:47 PM   #1182
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Yes, that's correct, with caps the offset will stay at its highest level all the time.
I had 47Labs Gaincard, that also uses input coupling caps, and offset was approx 80mV, so yours is not that much off
You may reduce input shunt resistor (R2) from 22k to 10k and that will lower the offset as well.
To order kits contact me through forum mail.
Old 21st July 2010, 08:54 PM   #1183
despite the offset the amp works fine!
Renato
Old 23rd July 2010, 06:38 PM   #1184
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
Originally Posted by Peter Daniel View Post
You may try adding small cap as described here: Commercial Gainclone kit- building instructions
If that won't help, try adding Zobel (Rz 2.7R and Cz 0.1uF on amp board).
If noting helps, you may be forced to add some shielding to amp circuit.
I have some amp running without any enclosure and in my listening environment it's not a problem, but with other setups it may be different.
Panic over. Wooden box is fine. No need for adhesive aluminium shielding. No need for a metal case. No need for zobels. Damned cordless house phone was the culprit. Chucking out the "throbbing" EMI. I've read they're the absolute worst for radiation harmful to humans too (ie worse than mobile (cell) phones or Wi-fi). A metre further away resolved it completely.
Many thanks to Peter and all who helped.
Lucas
Old 24th July 2010, 07:16 PM   #1185
Leglandu is offline Leglandu  France
Thanks for reporting Lucas, nice news...
Just for fun : I'm able to continue a call after I place the base of my DECT phone inside a stainless steel pressure cooker... and with the top cover in place !!!
Seems now "Low Radiation cordless DECT phones" exist, they don't have to permanently communicate with their base...
Welcome to the Frontpage
Not so easy to buy however...
Old 20th August 2010, 03:26 PM   #1186
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Steele Hammond Chassis with Walnut side Panels -> 7" x 5" x 2"
Hammond Mfg. - Steel Chassis & Bottom Plates with Walnut Side Panels (1441 CWW & 1431 Series)
This looks like a pretty good option for the shigaclone. I'm sure you can fit the assembly into it, and finish the top off with a sheet of frosted plexiglass.
Old 24th August 2010, 05:02 PM   #1187
pmchoong is online now pmchoong  Malaysia
pmchoong's Avatar
I have accidentally burned two mur860 in one channel. Can these to replace with MUR890? I am building Peter's LM gainclones (monoblock). Also, the LED light in the other monoblock seems to be turning off very slowly. It took a minute for it to turn off. The rail is at 27v. transformer is 2 x 25vdc. DC offset is at 80mv. what is wrong?
In picture 011.jpg, the bottom two mur860 are the ones which burned and the ones above are the mur890. The LED is shown in 013.jpg. I used a 62k resistor at R3.
Last edited by pmchoong; 24th August 2010 at 05:05 PM. Reason: describe attachements
Old 24th August 2010, 05:10 PM   #1188
udailey is offline udailey  United States
Passive Aggressive
LED turns off slow because you have capacitance that keeps it glowing until the capacitor is completely discharged. If you are using a regular LM3886 or LM3875 you do not need better than MUR860. How in the heck did you destroy one of those diodes?!
IF you have MUR890 laying around it will do the same job as the MUR860
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 24th August 2010, 05:17 PM   #1189
pmchoong's Avatar
Yes...but lights goes off in 1 minute???
Sigh..it was a stupid mistake...the v+ and the pg+ from the psu was suppose to connect to the v+ and pg+ of the main board....and i connect the pg+ of the psu to the 'chg' of the main board...and the v+ of the psu to the pg+ of the main board. Heard the transformer buzzz but I thought it was humm and then 'pop'..spark flew and i have two destroyed diode. i am using the LM3875. Can I sub the two mur860 with the mur890? I have the 890 but not the 860.
Old 24th August 2010, 05:21 PM   #1190
Passive Aggressive
Yes, the huge capacitance can run a little LED for a very long time. Yes the 890 is fine. Lets hope the chip is okay.
Uriah
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
