Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 29th April 2010, 07:57 PM   #1101
ss007 is offline ss007  United States
Thanks Koog! What about the additional bypass cap that carlosfm recommends?
Old 30th April 2010, 05:11 AM   #1102
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Originally Posted by limelight View Post
1. I left the input series resistor off, using a piece of bare copper. What effect on the sound do people perceive when adding that R?
2. I'm interested in at least listening to the amp with a snubbed PS. I'm taking it that RZ and CZ on the amp board are the zobel. What are the correct values to use?
They also talk about an additional bypass C along with the series R-C snubber network. Where does this C mount and what is the correct value?
1. They perceive the coloration of resistor, if the circuit works you are not missing anything
2. Those additional parts have been specified in the schematic I include with LM4780 kit, this also applies to LM3875 kit. BTW, it has been posted on a first page of this thread.
To order kits contact me through forum mail.
Old 30th April 2010, 02:59 PM   #1103
Thanks Peter, I guess I missed that image.
I think I've gotten myself confused over the snubber-zobel issue.
The Image you posted of the rectifier board and the extra series RC is how I understood the snubber network.
At some point I started thinking that RZ and CZ on the amp board were the series RC in the snubber.
Is the zobel on the amp board part of the snubber?
If it is, does it replace the series RC on the rectifier board or do I need both?
If it's not, what is it's purpose?
Sorry for all the beginner questions. Thanks, Scott
Old 30th April 2010, 08:15 PM   #1104
koogar is offline koogar  United Kingdom
koogar's Avatar
Hi Peter,
Just assembled your LM3875 classic kit everything seems well and sounding nice .DC offset seems with in limits -7.3mv to -46.8mv / -33.8 to -73.3mv with a 50K RK27 pot
i have a bit of DC on the incoming source from my DAC what is the best option to block it
replace R1 with a 4.7uf cap Or Leave R1 and put a 4.7uf cap on the back of the input RCA ?
Is it better to use polarized or non polarized and what would the orientation be for polarized
A) with the + towards the incoming signal from the DAC
B) - towards the incoming signal from the DAC
any suggestions for particular flavour cap ?
Many thanks in advance
Koog
Old 1st May 2010, 02:16 AM   #1105
JL888 is offline JL888  United States
the reverse recovery spike for an ultrafast diode will be much smaller and faster than with a normal recovery diode, and hence more easily damped with a snubber. I generally use whatever ultrafast diodes I have on hand, and damp them with a combination of ferrite beads and RC snubbers.
I found this in a 6 year old thread on chip amp diodes. What is the current consensus on the best possible diode in this application? Peter, do you still believe that although MUR860 is best in a ship amp, a different diode is best in a DAC circuit? What about in an active XO?
Old 1st May 2010, 01:27 PM   #1106
udailey is offline udailey  United States
Passive Aggressive
MUR860 sound good. Another to try is the MUR820 which is soft switching. I have had several people recently recommend to me to try Schottky diodes and thats my next project. Schottky was recommended to me for a preamp power supply.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 1st May 2010, 01:51 PM   #1107
I use MUR860 in all analog circuits. With digital I prefer MSR860.
Old 1st May 2010, 01:55 PM   #1108
Originally Posted by koogar View Post
with a 50K RK27 pot
I would replace R1 with small cap (4.7-10uF). BG N would be my preferred choice, but if not available try any other electrolytic (Rubycon Z series, Elna Silmics etc); + towards the incoming signal
Old 1st May 2010, 02:03 PM   #1109
Zobel is separate circuit from a snubber.
You can read about Zobel here: IC Audio Power Amplifiers and Zobel Networks: One Size Does Not Fit All | Digital Home DesignLine
Snubber was introduced to chip amps by CarlosFM, in order to make large PS filter caps more "friendly"
I don't use any of them in my amps.
Old 1st May 2010, 02:42 PM   #1110
Martin Prothero is offline Martin Prothero  United Kingdom
Martin Prothero's Avatar
I just finished integrated stereo LM3875 with built in NOS DAC (both premium kits) and am listening to the sound they make while writing this.
I am being patient before judging the sound until they are fully burned in and settled but some things are pretty obvious.
Very open, fast, and as real as any amp I have ever heard - at any price. I am used to a SET but this offers something else. I can perceive more micro detail, more subtlety but with added gusto and it all adds up to a greater sense of space ..more palpable. Isn't that what hifi is about?
Anyway I wanted to thank Peter for his support over the last few weeks via email. I have not wanted to ask all of my newbie questions and fill up the thread with what to others may be obvious stuff and Peter has helped me through the build like a true gentleman.
If anyone is sitting on the fence and wondering if it is worth it I can assure anyone that this really is something special.
THANK YOU PETER
Keep a green bough in your heart, the singing bird will come.
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
