| Audio Sector Kits & PC boards from AudioSector |
#1011 |
Yes, all pots are wired the same, most of them have 3 pins though.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#1012 |
Yes, unblanaced signal is fine with stereo or parallel configuration. Also, 8hm load is perfectly fine here, as it's easier to drive.
#1013 |
Peter, thank you for your patience. Hopefully this will be my last question regarding this.
If running in parallel: 1) install jumper, R8, and R9 2)Regarding inputs. Being there is now a jumper, do I use just the Red IN and associated SG or do I split the positive side between both IN's and SG between both SG's? 3)Red OUT goes to + side of speaker and OG to - side of speaker? |
#1014 |
When in parallel, install jumper, R8, R9, Do not install R0.
Use red IN and any of SG's (as they are connected anyway). For output, red OUT (//) and OG for output ground.
#1015 |
Ok, got it...Thanks
#1016 |
Hello, I've been reading this thread as well as this tutorial and can't seem to figure out what to solder to what.
Right now I have both reds soldered together and both blacks solders together as well. I don't want to risk damaging these transformers so if someone could clarify this for me please it would be greatly appreciated. Here is a picture.
#1017 |
Passive Aggressive
That transformer wont work. You have 22V secondary and 220V secondary. Wont work. If you had 22V and 22V that would be fine and you would tie the middle blue/green together to get a 0V for power ground.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#1018 |
Are you sure it's not a typo? Such secondaries configuration is rather strange.
Don't tie secondaries together but use them separately with my kits. Anyway, connect primaries in parallel (reds together and blacks together) and measure secondaries first.
#1019 |
I got 22.3V on the secondaries, most definitely a typo in that image.
#1020 |
I have both boards built. One has a dc offset of 118mv and the other 0.1mv. The second one has no output but the chip does get hot. Any advice would be appreciated.
| Commercial complete Gainclone kit for a beginner? | gychang | Chip Amps | 365 | 4th October 2011 08:19 AM |
