Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 29th January 2010, 06:48 PM   #991
captainobvious's Avatar
Send a message via AIM to captainobvious
Thanks Peter.
Just sent you an email.
The speaker impedance loads will be appx 4 ohms each. Parts Express has the 330V 25+25. Will this be acceptable? I dont see any 18+18 or 22+22...
Old 29th January 2010, 07:38 PM   #992
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
25+25 will work, although with 4ohm speakers lower voltage is really recommended.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th January 2010, 02:53 PM   #993
The closest that Avel makes are these two:
330VA 25+25 (secondary current 6.60A)
250VA 18+18 (secondary current 6.94A)
Unless you know of another supplier that carries something better, which of those two would be more appropriate ?
Old 30th January 2010, 03:36 PM   #994
I would go with 330A 25+25
www.audiosector.com
Old 3rd February 2010, 06:07 PM   #995
Looks like they are available from AnTek... 400VA 18v+18v
eBay seller "johnango"
For everyone elses reference, its AnTek model number AN-4218. Looks like I'll be ordering those since they would be the better fit.
The eBay link shows the tested specs as well...
18+18V 400VA Toroid Transformer DIY HiFi Audio Amp 4218 - eBay (item 370327724279 end time Feb-05-10 12:56:59 PST)
Old 4th February 2010, 12:25 AM   #996
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
At one point, John was offering diyaudio members a discount below the eBay price if you ordered through his website. This was for the F5. Might send him an email before buying through eBay.
Old 4th February 2010, 07:03 PM   #997
Wavne is offline Wavne  Canada
Hey Everyone;
I'm new here. I just ordered the 4780 Dual Mono Kit from Peter. While hunting for transformers I found these guys..Primrose Audio. Has anyone tried these?
I'm planning on getting One and run the kit in stereo until I can afford a second, then run in dual mono. I have a price of $125 CDN after tax and shipping for a single primary 300vac 22+22 secondaries.
regards,
Wayne
Old 5th February 2010, 03:24 AM   #998
j.leger is offline j.leger  Canada
Nice find. I wish I had found this outfit a long time ago. Seems a little pricy but nice.
Old 5th February 2010, 11:56 AM   #999
Originally Posted by Wavne View Post
Hey Everyone;
regards,
Wayne
You can ask Richard if he have surplus stock. I ordered from him two 300va 22-22 for 40$ each about two month ago. Check also for Antek, for more competitive price.
Old 5th February 2010, 02:57 PM   #1000
Regarding isolating the chip from the chassis/chassis mounted heatsink...The kits come with a strip of insualting foil. Do you need to use heatsink thermal compound on both sides of this foil (between foil and chip, and between foil and heatsink) ?
I read through the thread but couldnt find a clear answer on isolating the chip. Thank you.
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 365 4th October 2011 08:19 AM
Copyright ©1999-2013 diyAudio
