| Apex Jr Surplus Electronic Parts from Apex Jr. |
Hi Steve,
I am interested in the Cornell-Dubilier computer grade 12000uF 80V caps that you are selling. But in the product picture (see below) the caps have some kind of pins instead of screw terminals or the snap-in solder tabs. How should connections be made to these caps? Can one solder directly to the pins, or will that melt the housing??? Thanks for any help you can give. -Charlie
#2 |
Charlie.....
These were designed for PC Mount with one pin marked with a positive the other 2, one is - and the third is a repositioning pin to keep it straight on the PC Board. Yes, you can solder right to the pins and use shrink tubing to cover it. Steve |
| Computer grade caps limited quantities | Apex Jr | Apex Jr | 7 | 25th April 2012 11:08 PM |
| 4 x 10000uF 25V Computer Grade Caps | KatieandDad | Swap Meet | 0 | 18th November 2011 11:28 AM |
| Rebuilding a DAC Audio grade or Computer grade caps? | gto127 | Digital Source | 0 | 28th January 2009 08:17 PM |
| F/S 80V - 100V Computer Grade Caps | Apex Jr | Swap Meet | 0 | 22nd September 2006 01:55 AM |
| Computer grade caps | joke | Pass Labs | 19 | 19th September 2002 11:21 AM |
