#41 |
I just finished a design around these caps.......well, it could be modified to accommodate other caps. I was actually going to talk to you (Steve) about selling it....
Unregulated Power Supply: -Soft start/current limiting via relay. Primary power connection routed through high watt low resistance current limiting resistors till voltage rails reach a certain level. -Mute signal generated when rails fall below certain voltage. -Individual connectors for the addition of extra capacitors - so someone could hook up some computer grade chassis mount caps. -On PCB fuse or ability to connect off PCB fuse via dedicated headers. -Dedicated headers for connecting chassis mounted switch -Individual star-grounding points for earth ground, small-signal ground, and power ground. -Large caps on-board can accommodate capacitors with four leads with 22.5mm lead spacing and diameters of 45mm. Also can accommodate smaller caps with 10mm lead spacing. - Large current Molex z-power headers with gold plating that can handle 30A and you don't have to solder them in if you don't want to. Digi-Key - WM4668-ND (Manufacturer - 0760010006) -Sandbox area for add your own stuff. -compact design 8" x 5" The board itself is well designed, would be manufactured using 2oz copper, and the plating would be Silver Immersion (much better then gold). ![]()
#42 |
Max....
Started out with 800 of these caps. I knew they would sell but didn't know they would sell as fast as they did... I have feelers out and am trying to find something close or other caps at a good price but so far haven't found anything yet. I'm sure I'll post it here 1st as soon as I find something... I do now have some 33,000Uf 50V caps in stock. Listed in another thread. |
#43 | |
#44 |
Audio Junkie
NICE!
It's not about what you can BUY...It's about what you can BUILD! |
#45 | |
Who is the Manufacturer which can produce such kind of PCBs? Do You Have any experience ordering such PCB boards from it?
#46 | |
Here is a good chart that compares the different finishes: http://www.4pcb.com/media/Final%20Finish%20Chart.pdf I ordered 6 on my initial prototype run. They are 100% built up and I would be willing to sell 3 of the six. Let me know if you are interested. I will post a link to pictures in the next couple of days. Just busy with Halloween and work stuff. |
| Thread Tools | Search this Thread |
| 18,000Uf 50V (SOLD OUT) | Apex Jr | Apex Jr | 45 | 7th February 2012 10:38 PM |
| FS: Panasonic 18,000UF 50V SNAP-IN | Apex Jr | Swap Meet | 9 | 12th May 2010 03:06 PM |
| 15,000uf 80V Cornell Snap In Caps | Zero Cool | Swap Meet | 2 | 7th December 2006 11:01 PM |
| Selling Nichicon KG 15,000uf 63V capacitors | Ruach | Swap Meet | 1 | 22nd September 2005 08:57 AM |
| FS: 15,000uf 80Vdc snap in caps $5 | Zero Cool | Swap Meet | 3 | 28th June 2005 02:16 PM |
| Page generated in 0.08707 seconds (86.96% PHP - 13.04% MySQL) with 10 queries |
