| Apex Jr Surplus Electronic Parts from Apex Jr. |
Custom Title
I was hoping for some more detail on the Super 8. Dimensional drawings would be extremely helpful, as would a frequency response.
More than those, however, I would love to see a validation of the .157mH Le spec, which is extremely low, particularly for a driver of this type. If it's verifiable, then these jump up on the desirability scale by about 6 notches. Thanks!
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#2 |
Badman, I have an cheap and I do mean cheap meter that typicaly is off about 20%
using that meter I get .289 mh then using the CHEAP woffer tester from PartsExpress I get .45mh so that .157mh may be a little low. One strange thing about that driver is it has a rather wide bandwith. It's been a long time since I measured it but I think I rember it going to above 10K but having said that it does have a rather nasty peak about 2k but in subwoffer use that shouldn't be a major concern. Let me say again my measurements may be off a country mile.... Why does the low Le make it more desirable to you? |
#3 |
Custom Title
Low Le tends to mean a few things with respect to motors. 1 is that the Le(x) typically will be much flatter with a very low Le. This is source of distortion, though more high-frequency oriented. It also tends to be an indicator of certain characteristics in motors, mostly desirable. In this case, it may only be that there's a lot of clearance in the gap, to allow a little rocking during extreme (approaching Xlim) situations, though there is a chance, given the (impression of) build quality, that there's some shorting in the motor. It's likely a single-layer coil, too, and in whatever case, the steel seems like it'll be saturated under all conditions, which is obviously desirable.
#4 |
If you go back to the website and click on the picture there are
some more pictures and information listed about this driver. Also check this out; http://www.youtube.com/watch?v=P-fTjTcNQRM 3-17th-2011 found another link http://www.youtube.com/watch?v=XXif_q5YkLs Steve Last edited by Apex Jr; 17th March 2011 at 11:53 PM. Reason: Found another link to add |
#5 | ||
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#6 |
i Disected one of the Two Super 8's i bought...the Woofer is a Monster and the build quality is excelent....the Voice Coil was a 2 Layer 2" Coil on a Kapton Former...the Pole Piece was Extended,i dont have any means of Measuring to gather real numbers...but the Super 8 does play well into the midrange...however it is not particulary clean,and by ear it sounds a bit Peaky,and nasal...the bass extension is it's strong suite...despite the rather Stiff Suspension and Highish FS (Posted around 47 Hz) the Super 8 Plays Deep,and even subsonic notes Easily...(that Large Magnet must make a Very Strong Motor)....being advertised as an 8" Sub the Large Surround on the Super 8" means the actual cone area is more like 6.5",not a big deal considering its low bass capibility.
#7 |
I've been quite happy with my push-push Super8 woofer. I have measures but that doesn't include Lvc
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
Wish I'd have started this thread. I came within a nats hair of buying 4 of these a year back.
Couldn't find anyone who'd built them. Got a deal from another member on some TB long throw 8's so went that route. Haven't decided what to build with them. Numbers are fairly close as I recall and was toying with Dave's design on the Apex Jr. site. Sorry to hear opinion that the TB's aren't of same quality as the little Apex Jr. As long as we're here; how about some comparisons by those experienced between Steves available amps with Dayton or OAudio. |
#9 |
That's interesting. I'm considering a pair of Fonkens and wondering if it would play nice with a push-pull Super 8 for bass-heavy music. Would appreciate your opinion...
#10 |
Up till now i've only been using the Apex PP with the HT (& a variety of mains including the Fonken)
I've been thinking of hooking it up to the mains now that i have a stand alone plate amp. I'll let you know. dave
| Nirvana super 8 and cast super 8 how do they compare to 206E? | freddi | Full Range | 4 | 22nd October 2010 03:29 AM |
| Questions on reference and noise in the super regulator | Lucien | Power Supplies | 1 | 4th August 2008 10:08 PM |
| More Super T-amp questions | 3-LockBox | Class D | 1 | 15th June 2006 12:46 AM |
| Some questions froma super-newbie: charlize and monica2 | ExecutorElassus | Chip Amps | 0 | 18th April 2006 03:31 AM |
| super duper newbie questions | M5150 | Multi-Way | 13 | 9th February 2002 03:47 AM |
| Page generated in 0.11609 seconds (80.42% PHP - 19.58% MySQL) with 11 queries |
