#21 |
Thanks Steve, wich voltage are rated? how much cost 12 caps shipping to Spain (Europe)?
Felipe |
#22 |
They are 400V and will get you an exact cost Jan 6Th when I return
from vacation Steve |
#23 |
Thanks I wish you a happy vacation, BTW do you have 22uF also MKP pr higher than 10uF?
#24 |
Hi Steve
I would like to know how many Rifa 10uF phe426 can fit in a $16 bag , I want about min 14 Rifa 10uF and 4 X4.7uF and AB resistor 1W or 2W , the value is 2 X 50R and 2 X 200R or close value , and payment method please Regards |
#25 |
Merlin El Mago...
No box type above 10Uf at this time do have some Aerovox Axial lead metalized polyproplyne in both 24 Uf and 28Uf 250Vac in stock Meganinja I can fit 24 in a Flat rate envelope The 4.7Uf will also fit Also can add the resistors, here's what I have 47 Ohm both 1 and 2W 51 Ohm both 1 and 2W 180 Ohm 2W 200 Ohm 1W Steve |
#26 | |
I will take : 24 Rifa Phe426 10uF 04 4.7uF 4 x 51R 2W 4 x 51R 1W 4 x 200R 1W Please PM paypal account and the total . Regards Meganinja |
#27 | |||
Felipe |
| Thread Tools | Search this Thread |
| bypass caps for bypassing mylar caps? | crippledchicken | Multi-Way | 4 | 27th February 2008 04:24 AM |
| Replacing multi-section caps with multiple caps? | Sir Trefor | Tubes / Valves | 1 | 29th May 2007 10:17 PM |
| Silver Mica caps VS Polystyrene caps | KevinLee | Parts | 24 | 17th September 2003 03:01 PM |
| Replacing ceramic disc caps with silver mica caps? | G | Solid State | 5 | 18th November 2002 01:02 PM |
| FILM Caps to assist Big ELYT Caps | gromanswe | Parts | 0 | 9th July 2002 08:16 AM |
| Page generated in 0.08736 seconds (79.05% PHP - 20.95% MySQL) with 10 queries |
