| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I think I need to replace a piece of my Pioneer PL-41's bearing. I don't know the correct terminology for everything, so bear with me. As it was assembled, the bottom of the spindle sits in a screw off cap on top of (from top to bottom) a plastic disc, two metal discs and finally the cap. The plastic disc appears to have shrunken and broken into several pieces. Because of the damage, I can't be sure if the plastic disc was solid and wore away, or if it had a conical divot in which the bottom of the spindle sat. Does anybody know what it should look like? Was that the order in which it was assembled originally? What should I replace the plastic disc with? I'm thinking teflon, but would any cheap easily procurred chunk of plastic do? Here are some pics to show the problem.
pj |
#2 |
Here is the bottom of the bearing:
#3 |
And the top:
#4 |
as do many others from the late 1950s and 60's
The plate should be made of DELRIN, and has a small indentation machined in it where the ball sits There should be 2-3 teaspoons of oil in the bearing well Its a simple repair and will last for decades if the turntable doesn't run out of oil You could make and order the Part online here: http://www.emachineshop.com/ Best El Gippo
Electric Gypsies |
#5 |
Thank you very much. The indentation is the key detail for me. I was planning to just buy a sheet of something and cut a circle myself. However, getting the indentation right in the center might best be done by a machine shop. I'll look around locally, but I may well use those guys to whom you linked.
pj |
#6 |
BTW, I should mention I own a Pioneer PL turntable from the mid 1960s that has the same spindle/bearing setup
If you download the emachineshop software, which is v. easy to use, input the measurements you need and the material, you can order that part online The dimple in the Delrin is just that; its only 1.0mm across when these are new I'm sure its only to allow a little oil to sit directly under the hardened steel ball that's welded to the spindle By careful measurement and centre-punching the Delrin as a guide, there's no reason why you couldn't make that dimple yourself by hand with an "egg beater" hand drill or the end of a file, the indentation is spherical, so just the tip of a drill touching the Delrin for a second would do the trick Delrin isn't hard like perspex, it's more like nylon, + has a bit of give Nice turntable: check the rubber grommets that hold the motor, these decay and that causes vibration ( easily replaced ) The platter could do with a Mat or some damping material 'cos these are cast aluminum and ring like a bell A little bit of minor maintenance + tweaking and you'll have a very fine turntable! Best El Gippo
Electric Gypsies |
#7 |
Thank you PJ for this question & photos.
I purchased a PL-41 several days ago and wouldn't have known that I needed a bearing. Your posting came up when I googled PL-41. My bearing looks just like yours. Please let us know what route you take in making/purchasing the bearing. Thanks to El Gippo for the great info. Just to clarify, it is just a 1mm dimple, not through the material? Also, the motor has an oil wick, will 3in1 oil do? Would appreciate any additional advice on this fine machine. OB |
#8 |
El Gippo takes a Bow
2-3 teaspoons of a multigrade engine oil like 20W-50 will do the trick for the *spindle* 3-in-1 Oil is too light for this application, but it's OK for the motor ( just use a couple drops tho' ) The dimple does *not* go all the way through the material on an Empire or Pioneer turntable and the Delrin rests at the bottom of the bearing well with the screw-on metal cap supporting it I would make the Delrin thrustplate between 1/8th and 1/4 in thick, and the same size as the internal diameter of the bearing well, so it's a "press-in-with-your-thumbs" fit Thickness of the Delrin will affect the "ride height" of the platter; that isn't that critical in this application as you'll see; you may need to adjust the ride-height of the tonearm ( which you would do if you were fitting a new Cartridge, for e.g. ) *No Biggie* Put some gasket goop or silicon sealer at the top of the screw-on cap where it meets the turntable body to save oil leaking out of there; going dry is how the Pioneer thrustplate collapsed and caused the problem That won't have damaged the spindle or spindle ball, the thrustplates are designed to be sacrificial in these old designs; no harm done *ReOil the spindle every 5-10 years, having cleaned out the bearing well 1st *Replace the Delrin thrustplate every other lifetime ( make a note on your 2090 PalmPilot now; so you don't forget El Gippo
Electric Gypsies |
#9 |
I wouldn't bother with the dimple you describe in the thrust pad. Delrin would be a good choice but it didn't exist when your turntable was made - Nylon is probably the material used and the dimple will largely be the effect of wear. The dimple serves no useful purpose if the bearing sleeves are dimensionaly accurate - if, however, they are rather 'sloppy' the dimple will be centering the bearing to a point (no pun intended).
#10 |
Disagree, and here's why:
I'm in possibly a unique position to comment; having owned both an Empire 208 and a Pioneer PL 12 which were both NOS ( actually new in the box ) as well as numerous turntables that were used that have this construction Both very similar build to the PL 41 mentioned here, and while I had always assumed the "dimple" in the bottom of the bearing well had been worn there by the hardened ball in the spindle, in fact the manufacturer had machined one there when these were new in both the Empire and the PL 12 I'd suggest its just to trap a drop of oil so the spindle ball never contacts the thrust plate completely dry; engineering overkill, a valid theory, or otherwise, that's how they did it when these were New While a material like phosphor bronze will soak up oil like a sponge ( as will cast iron ) these wouldn't make good materials for a thrust plate here because these would wear too fast, and would be hard enough to damage the hardened spindle ball over time The nylon/Delrin doesn't have particularly good oil absorption properties, hence adding the dimple, but Delrin to is too soft to damage the spindle by contact over time You are 100% correct that Delrin wasn't available back then, and that nylon was. Delrin was mentioned as it's proved to be a superior material for this repair and won't wear out anywhere near as quickly as replacing the original nylon part with nylon The Electric Gypsy
Electric Gypsies |
| TT bearing | wuffer | Analogue Source | 22 | 7th February 2008 11:24 AM |
| The perfect Bearing | Salar | Digital Source | 2 | 10th April 2007 07:13 AM |
| DIY platter bearing | cougarnut | Analogue Source | 17 | 9th September 2005 02:16 PM |
| Page generated in 0.11210 seconds (82.28% PHP - 17.72% MySQL) with 11 queries |
