Old 23rd March 2007, 09:59 PM   #1
Default shure V15VxMR
does anyone use one of these?
If so, brush down or brush up? My instinct tells me to get the brush out the way, but the manual makes it sound pretty important. Its also a bit wobly with it up.
Whats the opinion?
Old 24th March 2007, 01:03 AM   #2
nuvistor's Avatar
I use V15VMR, has the same brush. I always keep the brush up, noise is added with brush down especially in silent passages between loud passages, apparently the bristles are vibrated by adjacent grooves. I guess you wouldn't notice with rock music, but I listen to a lot of classical and some jazz. If you play clean records and perhaps adjust tonearm damping the brush is pretty much superfluous.
Old 24th March 2007, 11:16 AM   #3
Ok thanks. It does seem to make the cart steadier though.
Ill experiment both ways and see what i prefer.
Old 3rd April 2007, 11:08 AM   #4
I had the earlier version and found no consistent improvement with the brush up or down.
I removed it completely to reduce resonances feeding back into the generator.
regards Andrew T.
Old 16th April 2007, 03:03 AM   #5
I use it down on warped records to stablize the stylus to groove contact and I found it works rather well for this.
Old 18th April 2007, 07:46 PM   #6
JimB is offline JimB  United States
I have used this cartridge in a Rega RB-300 for many years. The instruction sheet that came with the cartridge says that the brush in the down position supplies a counterbalancing force of 0.5g, so that the tracking force should be set 0.5g higher to compensate. So, if you lower or raise the brush, you should reset the tracking force accordingly. The fact that your cartridge appears "wobbly" when the brush is raised might be due to excessive tracking force???
Replacement Stylus for Shure V15VxMR phibes Analogue Source 19 12th December 2007 11:38 AM
AT ML440 vs Shure V-15 ashok Analogue Source 3 4th January 2007 04:13 PM
My Shure E5's on ebay imix500 Swap Meet 0 30th August 2006 02:07 AM
Shure M31 jaudio Analogue Source 1 6th July 2006 08:59 PM
Page generated in 0.08959 seconds (75.06% PHP - 24.94% MySQL) with 10 queries
