Interesting norwegian RIAA amp
Old 10th January 2003, 05:52 PM   #1
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Default Interesting norwegian RIAA amp
http://home.no.net/andiha/articles/a...afig/riaa1.gif
Interesting RIAA amp with descrete design and DC-servo.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 18 pcb's in interest.
Old 10th January 2003, 06:13 PM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
The riaa network appears to be fed by the current mirrors (transconductance amp). Is it possible to calculate the driving impedance with sufficient accuracy?
cheers
peter
Old 10th January 2003, 07:02 PM   #3
Cobra2 is online now Cobra2  Norway
DIY !
Cobra2's Avatar
Interesting norwegian RIAA amp Interesting norwegian RIAA amp
Default And there is more...
here..:
http://home.no.net/andiha/articles/audio/index.htm
ArneK
Old 11th January 2003, 07:14 AM   #4
peranders's Avatar
It's not kind of taste of driving RIAA networks but I think that the output impedance is rather "resistive" in the audio band, therefore the gain wil be predictable.
It's also not my kind of taste to have parameters that give varying results. The gain (I suspect) will differ between different amps because the transistor parameters will variate.
Old 11th January 2003, 07:31 AM   #5
analog_sa's Avatar
Peranders
I was not worried about the gain but rather about RIAA accuracy. Don't you need to know very accurately the driving impedance in this configuration? There doesn't seem to be a resistor between the transconductance amps and the 'passive' RIAA.
cheers
peter
Old 11th January 2003, 09:32 AM   #6
peranders's Avatar
Peranders
The "resistor" is the output impedance and the gain will variate but, not the much the RIAA curve looks, just a little maybe.
Old 11th January 2003, 11:58 AM   #7
analog_sa's Avatar
It's obvious the output impedance is the 'resistor'. But how do you calculate its value without knowing the current gain of the transistors? That's why normally there is a resistor with value a lot higher than the preceding stage output impedance. Is this circuit supposed to be tuned to the selection of active devices?
peter
Old 11th January 2003, 02:30 PM   #8
peranders's Avatar
When I've taken a closer look I believe that the DC-gain is (R23/R17)/2, quite predictable.
Old 11th January 2003, 10:10 PM   #9
halojoy is offline halojoy  Sweden
On Hiatus
Arrow Andiha homepage
If I was to judge by the formulas at Andiha Homepage Andiha Audio
I would say he probably knows what he is doing.
This page for example, makes me DIZZY just by a quick glance:
The Complete Amplifier
And this is what he is talking about
a typical voltage feedback operational amplifier
Interesting norwegian RIAA ampHide this!Advertise here!
Fix my RIAA thuur Analogue Source 7 24th November 2008 03:48 PM
interesting amp & interesting problem m6tt Tubes / Valves 9 14th August 2007 07:28 PM
Just another RIAA...... Chris Analogue Source 26 8th June 2003 08:34 PM
fet-riaa with LCR? Onvinyl Analogue Source 13 1st May 2003 11:42 AM
