| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I want to make a platter, well, a think platter matt to be precise.
Just wondered what the best material for the job would be. There was talk on here about acrylic being too hard and PVC being the right match to vinyl records, but what about other plastics? What will couple with the record best? It will be around 10mm thick (or more) and will sit ontop of a glass platter. It will have no other matt on top. My options are PTFE Nylon 66 PVC Polypropylene polyethylene Acetal I can find all the hardness ratings etc, but i dont know what the ideal is. thanx folks. P.S. heres the lists of options http://www.altecweb.com/home.asp?cat=category3700 scroll to the bottom for other materials. |
#2 |
get some old records...
a heat gun...... and......
hoping to pick up some things. |
#3 |
Ive thought about it, but making a nice job of it will be hard, and im sure i'd introduce air bubles.
I may yet try it though. |
#4 | |
I have a nice collection of totally worthless, scratched-up LPs that came with the house I bought a couple of years ago...... |
#5 |
Try a soft material with good damping properties,under the glass platter.A viny mat ontop won't be much better than the LP alone with a clamp.On the other hand,if you damp the glass resonances well,you have a neutral platform for your LP's.
#6 |
I was hoping for 1" thick PVC top platter, but cant find it that thick. Looks like 10mm is the thickest i can get.
Im hoping 10mm will damp the glass better than a thin matt as well as providing a nice solid coupling between the record and the platter. |
#7 |
BBC engineers used a star mat with their modded garrard 301s. If it's good enough for the BBC, it's good for me...
It's very easy to make. It is just a sheet of aluminum with six buytl rubber pads. |
#8 | |
Have you considered a mass loaded vinyl like this 2kg/m² or this 5kg/m² ?
Haven't tried it my self, no TT set-up at the moment, but the sheets are fairly cheap, you might be able to get a cut-off from an installer? There are quite a few patent out their to learn from. TURNTABLE SHEET FOR RECORD PLAYER, JP patent 55129905 Quote:
Regards James
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson |
#9 | |
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| DIY acrylic platter | JVDM | Analogue Source | 47 | 8th January 2009 06:03 PM |
| rega p3 platter on a p1? | jicas | Analogue Source | 8 | 17th January 2008 02:57 PM |
| Platter | hifido | Analogue Source | 0 | 6th November 2006 08:17 PM |
| Platter material | A3rd.Zero | Analogue Source | 15 | 6th May 2004 03:07 PM |
| TT platter bearing | Ilianh | Analogue Source | 17 | 16th April 2004 10:05 PM |
| Page generated in 0.09690 seconds (80.65% PHP - 19.35% MySQL) with 10 queries |
