Old 23rd February 2007, 08:03 AM   #1
Default Driving a REGA Planar 3 with my CD player
HI dears,
I was thinking to do the following: produce a sine waves on CD and a second sine waves with 90 degree of shift on the same file (right and left channel). Then use a stereo amplifiar and a send the stereo signal to the AIRPAX motor on my REGA PLanar 3... this should provide the motor a pure 50Hz sine wave that should make the speed more accurate.
After doing that I will tune the frequency generated so that the deck will reach extact speed.
My only concearb is the voltage. The motor should work at whatver voltage, but the voltage will affect the motor vibrations, do you waht is the suggested minimum volatge for this motors (Rega, Linn like)?
JC
Rega Planar 3 PSU resistor kimmo Analogue Source 8 3rd March 2008 11:23 AM
Differences in Rega P3 vs Planar 3 augerpro Analogue Source 29 22nd June 2007 10:19 PM
Rega Planar 3 owners Sarchi Analogue Source 6 19th May 2006 03:44 AM
Rega Planar 2 Bearing Redart Analogue Source 1 9th April 2006 09:19 AM
Rega Planar with Marble Top ???? LuvPioneer Analogue Source 4 26th April 2004 05:43 PM
Page generated in 0.05877 seconds (66.27% PHP - 33.73% MySQL) with 10 queries
