Magnetic turntable bearing
Old 13th June 2007, 08:04 AM   #111
jrevillug is offline jrevillug  United Kingdom
That is an Amazing TT. Brilliant work.
I would like to build something similar, one day...
Old 15th June 2007, 01:15 PM   #112
livemusic is offline livemusic  Israel
Congrats, vinyl-addict - outstanding job!
Clever and simple engineering and tasteful aestetical look combined with top-class work - it is rarely seen combination in DIY world.
Old 15th June 2007, 05:41 PM   #113
Vinyl-Addict is offline Vinyl-Addict  United States
Thank you both for the kind words.
I am more fortunate than most DIY folks since I have a fully capable machine shop at my disposal along with CAD/CAM software, etc. The DC drive is Mark Kelly's design so many thanks to Mark for offering that to me.
Old 16th June 2007, 07:52 PM   #114
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Mark Kelly's design.
so a DC voltage controller? I am looking for an AC one, any ideas?
stew -"A sane man in an insane world appears insane."
Old 3rd July 2007, 10:18 PM   #115
Triumph is offline Triumph  Netherlands
Triumph's Avatar
Wish I have read this thread before. As Ynwoan mentioned in his first tread:
I have read elsewhere on the forum that the edge of the platter can be seen to rise and fall with some magnetic bearings
My experimenting with two neodymium ring magnets (see picture below) failed because of unbalance of the platter, not because off axial forces but of tangential forces of the magnets. Even after honing the sliding bearing to a minimum tolerance the platter has a “tide” of 3 mm.
It must be possible though, see:
http://images.google.nl/imgres?imgurl=http://www.coolgales.com/store/images/ClearaudioMagneticBearing70.jpg&imgrefurl=http://www.coolgales.com/store/cart.php%3Ftarget%3Dcategory%26category_id%3D44&h= 45&w=70&sz=3&hl=nl&start=7&tbnid=VV_pvs-iHL5s_M:&tbnh=44&tbnw=68&prev=/images%3Fq%3Dclearaudio%2Bmagnetic%26gbv%3D2%26svn um%3D10%26hl%3Dnl%26client%3Dfirefox-a%26channel%3Ds%26rls%3Dorg.mozilla:nlfficial%26 sa%3DG
Triumph
Old 3rd July 2007, 10:22 PM   #116
Triumph's Avatar
Sorry,
The Clearaudio magnetic bearing link:
http://www.coolgales.com/store/cart....category_id=44
Triumph
Old 3rd July 2007, 10:44 PM   #117
Judging from your thumbnail image, it looks as if the magnets are way too far apart and the platter is also extended too far as well. I can see how you would obtain poor results if that is an accurate picture of what is going on. My magnetic bearing only deviates 0.1mm and that is most likely due to the acrylic platter's imperfection.
Old 3rd July 2007, 11:55 PM   #118
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Magnetic turntable bearing
loaded with the platter ynoans magnet only floats the platter by a couple of mm. he uses a LINN bearing so the spindle is sleeved all the way up, hence no increase in lateral play.
this solution doesn't work so well with garrard and lenco style bearing as the spindle is quite short, you would need thin magnets of greater circumference so that they sat outside of the platter stub as shown in your image.
Paradise Pre-reg PSU PCBs
Old 4th July 2007, 05:18 AM   #119
Triumph's Avatar
The picture shows the distance without the weight of the platter. With the platter it is also only a couple of mm.
In a later version a made 3 adjusting screws for leveling the bottom magnet and also a adjusting mechanism for the top magnet but still it couldn’t prevent wobbling of the platter.
Were to order magnets:
http://www.monstermagnete.de/catalog/index.php?cPath=37
Triumph
Old 4th July 2007, 01:08 PM   #120
https://supermagnetman.c3.ixwebhosting.com/login.php
a bit further away but he does stronger magnets and more ring sizes.
the 41mm fits a rega platter perfectly.
Magnetic turntable bearingHide this!Advertise here!
Other bearing for turntable use? Zero One Analogue Source 9 8th November 2017 05:22 AM
Air Bearing Spindle DD Turntable monsieurphot Analogue Source 18 12th April 2008 07:05 AM
DIY turntable bearing bigbulb Analogue Source 9 11th July 2005 02:16 PM
Turntable bearing Tee-Rex Analogue Source 3 5th May 2005 06:55 PM
turntable bearing design sc351cobra Analogue Source 1 24th March 2005 10:30 AM
