Comments to PCB of Hiraga PrePre - diyAudio
Old 4th February 2007, 11:41 AM   #1
masag is offline masag  Germany
Default Comments to PCB of Hiraga PrePre
Hallo to everybody,
I am not very expierenced in Audio Electronics but did some tweaking before (Philips CD880 new analog stage, Jung line stage in my Rotel preamp.)
This is after a long break my first project. The four 2SB737R had to wait 15 years for their performance.
Powered with two 6 V batteries. I am using nonmagnetic dales, 4700uF Panasonic FC, and 1,5uF Mcaps from www.schuro.de
The input and output and battery ground are fixed to the star point.
Maybe the more expierienced diy-ers could have a look on it?
I don't know where I should mount the load resistor for my DL103?
Thank you
Sam
Old 4th February 2007, 11:43 AM   #2
Default Schematic Hiraga PrePre
and here is the original schematics
Old 4th February 2007, 11:54 AM   #3
jan.didden's Avatar
Hi Sam,
The simplest way for the load resistor is across the input connector...
But what is the value of the load resistor? The input impedance of this prepre is VERY low (couple of ohms) so do you need that load resistior?
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 4th February 2007, 12:43 PM   #4
Default Load resistor
Dear Jan,
thank you very much for the fast replay.
I know your articles well from AA.
My friend is using a 100R or 68 R Load resistor.
Do you think I should try it with out a load?
Sam
Old 5th February 2007, 06:37 AM   #5
euro21 is offline euro21  Hungary
Hi Sam,
Hiraga prepre designed for DL-103 loading.
DON'T try any parallel resistor!
It's working fine with old, and new DL-103 series (aprox. 26 and 40 ohm) too.
Old 5th February 2007, 08:28 PM   #6
Hallo EURO21,
Thank you very much for your help.
Now I understand what you mean.
The input resistance itself is very low, and does not need a parallel resistor.
Herzlichen Dank,
Sam
MC prepre with submini tubes PTSOUNDLAB Tubes / Valves 10 22nd April 2009 03:04 AM
WTB Hiraga PCB webercarbmann Swap Meet 1 18th February 2009 07:16 AM
Hiraga 30w PSU azoran Solid State 0 1st April 2007 03:32 AM
PCB hiraga 20w ninoslav Solid State 0 22nd March 2007 09:58 AM
Hiraga vs. ZEN or SOZ Selfmade Pass Labs 26 28th May 2003 10:21 PM
Copyright 1999-2017 diyAudio
