Old 20th January 2007, 02:46 PM   #1
hacknet is offline hacknet  Singapore
Default Lenco L70 plinth rebuild
after 2 years of feet dragging, i finally finished my plinth for my lenco L70.
its a mdf and ply sandwich. 6 layers of 18mm mdf and 6 layers of 3mm ply. inbetween the bottom most layer, i used 3M double sided sponge tape instead of the ply.
the plinth orignally sounded very lean in the midbass. a rubber and steel washer combo to place between the 2nd and 3rd layers helped to fatten up mid bass. placing this spacer too far up made the mid bass sound too fat, too far down and it sounded too lean. spent an afternoon tweaking and i found that placing it inbetween the 2nd and 3rd yield the best balance
i am thinking of taking it down from the rack and placeing it on an ikea lack table.. any suggestions?
Old 20th January 2007, 07:36 PM   #2
Floric is offline Floric  Europe
Very interesting,
I prefer Plywood over MDF for plinths, MDF dampens too much, I think.
What tonearm are you using there?
Floric
Old 21st January 2007, 03:40 AM   #3
yeah, i totally agree with you!
im using a unipivot made out of aluminium u channel, very much like the altman concept.
im thinking of ways i can improve the plinth.. me thinks it needs a new rack.
Old 21st January 2007, 09:49 AM   #4
owen is offline owen  United Kingdom
Arrrgggghhh.. I hate 'teaser' shots...
More Pictures! More Pictures!, More Pictures! (especially of that arm )
Congratz that you've finally got to the point of being able to listen, and from here the journey begins 8)
Owen
Old 21st January 2007, 11:47 AM   #5
My plinth is made of three layers of birch plywood and two layers of beech plywood that are glued to each other. This provides a little damping because of the different materials in the layered structure and it provides a lot of mass. Sounds quite good.
It is important to glue the layers together.
For more questions, I would refere to the lenco-lovers forum
Old 21st January 2007, 02:13 PM   #6
from the top
Old 21st January 2007, 02:14 PM   #7
side view
Old 21st January 2007, 02:17 PM   #8
im having alittle trouble with the counter weight. i need to make a circular weight with a threaded hole in the middle so i can adjust the vtf without loosening the screw..
i'm thinking of a ply plinth next.
got myself a lack today and i am not very impressed. not exactly a fanastic table for the lenco.
Lenco L75 tomat Analogue Source 11 9th June 2011 04:43 PM
chestnut for a Lenco plinth? harrygrey382 Analogue Source 3 3rd October 2007 09:18 PM
Lenco plinth cutout plans? fishwinker Analogue Source 5 3rd September 2006 02:11 PM
Lenco 75???? Havoc Analogue Source 13 27th September 2004 07:11 PM
Lenco L75 Help. streams Analogue Source 10 24th July 2004 10:40 AM
Page generated in 0.08505 seconds (79.95% PHP - 20.05% MySQL) with 11 queries
