Just another RIAA......
Old 5th January 2003, 06:11 PM   #11
Chris is offline Chris  Norway
Chris's Avatar
Hi Peranders
Yes Nemko would most certainly their heads if they could see
the wiring. Thats why I`m in the process of making it better right now... No more unisolated parts !!!
Old 6th January 2003, 11:38 AM   #12
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Actually, it says;
"Recommended load capacitance: 200-400 pF" on the ortofon website...
Mads K
Old 5th June 2003, 02:38 PM   #13
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Just another RIAA...... Just another RIAA......
Default Even when the sun is shining...
As a "hard-core DIY'er", I have kept on.... And now;
QSXM3 (PerAnders' design).
Just finished the board, on test now :-)
Arne K
Don't believe everything you think...
Old 5th June 2003, 02:54 PM   #14
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Does it work yet?
Arne, do you have DC-servo PLUS capacitor? Either one fat mama or DC-servo. Check carefully how you choose between "Linear Tech original" and "P-A original" feedback network.Check here and the part about DC-servo.
Note also parts for optional compensation.
We had a diy party when we used my monster QSXM2 together with a homemade TT with tangential arm. Look at the painting of the TT! I thought it was plastic imitation.
We hadn't time to REALLY listen to the amp or TT but it didn't sound bad anyway. The power came from two norwegian Mascot lab PS, not very high tech.
http://www.hififorum.nu/topic.asp?TOPIC_ID=14408
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 53 pcb's in interest so far.
Old 5th June 2003, 03:29 PM   #15
DIY !
Cobra2's Avatar
Default Yes, it works
Even being a bit "over-stuffed" !
Have to verify the parts-count again...too many options...
BTW, may I also have a few more dB (4-5) gain on MM?
And how much gain is it set up for on MC?
Arne K
Old 5th June 2003, 06:15 PM   #16
peranders's Avatar
I suggest that you make the DC-servo working as intended, remove the C11, C12, C13. Use not R5, R23.
You may otherwise get the "golden ears" haunting you. You must achieve accurancy below 0.1 dB!
More gain:
MM R6, MC R4. Half the value double gain = 6 dB
MC has 20 dB more gain. Note the differnce between R6 and R4.
Old 5th June 2003, 06:36 PM   #17
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Originally posted by Chris
The sound is nice. Good soundstage, relaxed but dynamic..
However it has a somewhat enhanced s-sound.
The Ortofon OM10 is a bit sibilant, that's almost certainly the cause of your "enhanced s-sound." I had an OM10 in an SME3009 S2, and had the same problem, so I changed the stylus for an OM30 stylus (the bodies are identical), and the problem went away.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 5th June 2003, 06:46 PM   #18
DIY !
Cobra2's Avatar
Default Re: QSXM3
Will do, PerAnders, have not listened to it yet, more than confirming that it works, and is very quiet :-)
Arne K
Old 5th June 2003, 08:35 PM   #19
Mad_K's Avatar
Yepp, I did the excact same thing
Mads K
Old 6th June 2003, 01:03 AM   #20
DIY !
Cobra2's Avatar
Default Re: QSXM3
And it also sounds great ! Now, I need to find a home for it (chassi).
A little gain-adjustment 100ohm -> 75ohm was what I needed.
All components are matched, even had to order another 10 of the RIAA caps for getting a match...
Arne K
Just another RIAA......Hide this!Advertise here!
lcr riaa Raj1 Analogue Source 2 24th April 2014 11:56 AM
Fix my RIAA thuur Analogue Source 7 24th November 2008 03:48 PM
fet-riaa with LCR? Onvinyl Analogue Source 13 1st May 2003 11:42 AM
Copyright ©1999-2017 diyAudio
