Just another RIAA......
Re: Re: QSXM3
Cobra2 said:
And it also sounds great ! Now, I need to find a home for it (chassi).
A little gain-adjustment 100ohm -> 75ohm was what I needed.
All components are matched, even had to order another 10 of the RIAA caps for getting a match...
Didn't you use 2.5% caps? Is it polyester....green? :magnify:
Now the picture looks better but how about the class A circuit? FET + resistor only.
Joined 2002
Re: QSXM3
6800pF + 2,5% = 6970...
And when I do critical matching, I try to go for +/- 0,1%. :cool:
Witch "wastes" a lot of components....:bawling:
Having looked over the schematics & instructions, I think I have removed the surplus components, exept a few, that should be isolated from the circuit anyway (without transistors).
ArneK
Hi to everybody;
i am currently working on a opamp based phono stage as well. I saw the circuit of the 606 data sheet and it is quite the same as mr lehmann uses (black Cube) except the opamps and a dc coupling cap/subsonic filter.
My plan is to do it like shown on the picture, but i did not finish planning yet. I ordered several OPAmps like AD797, SSM2019, INA217, OPA627 and OPA637. The goal is to have a quiet phono stage, which forces to choose from very few opamps for input stage. Apart from the first three of the obove mentioned there are only a few more to mention: LT1028, THAT1510.
The circuit will be working, but i am not sure about the 1K5 cap on +input of second OPAmp (whether it will change RIAA ...?) and about the output resistor and if i should put a further cap in series with that 100R.
Cheers Christian.
