Old 21st September 2012, 10:49 PM   #21
Originally Posted by sq225917 View Post
Adjusting the phase offset gives you a real and meaningful improvement in vibration. Fiddling with motor drive voltage largely just reduces torque and is a crutch for incorrect phase offset.
so how does on go about measuring a motor? what do you need to do to adjust the phase offset? Do the individual windings need to be measured and what equipment is necessary to do this? I have an AC motor which vibrates too much to use perhaps this is all that is wrong? Thanks for any assistance or direction. Best regards Moray James.
moray james
Old 22nd September 2012, 11:46 PM   #22
Send a message via MSN to sq225917
Which motor is it? Manufacturers specs should lead you to roughly the correct value +/-10% or thereabouts. You can measure the coil resistance and inductance and calculate it from there, or start with the recommended capacitance and add a 10% trimmer cap into the mix.
hoping to pick up some things.
Old 26th September 2012, 07:19 PM   #23
it's a french motor a Cruzen I think. I have the manufacturers suggested capacitor value. What would I expect to see for winding resistance values? Is going to be something I can measure with a multi meter? I do have access to an inductance meter as well. Should I be starting with a smaller cap and add the trimmer cap on? What is the process? Do I simply adjust the value till running operation seems smoothest or is there something specific to measure for? Thanks. Best regards Moray James.
moray james
Old 26th September 2012, 09:57 PM   #24
If you have the manufacturers value then there's little point bothering to calculate it based on measuring the motor, so skip that step.
I would start with 10% less than manufacturer recommended capacitance and work through increasing it to 10%+, via a trimmer or maybe substituting smaller cap vales to home in on a rough value.
If you hold the motor in one hand while it is turning you will feel the vibration increase and decrease as you adjust capacitance. I found the best value for mine was just under 0.2uf, the manufacturer recommended valuer is 0.22uf, the difference was significant both in vibration felt through the hand and also from a full speed demodulation produced from a 3k test tone when it was re-fitted to my deck. There's a great thread on Pinkfishmedia in the diy section called 'turntable sped analysis', there's a lot of good info in that thread.
http://www.pinkfishmedia.net/forum/s...ad.php?t=70027
Old 1st October 2012, 09:03 AM   #25
I may be a little obvious, but one very effective way to reduce vibration is to dump the AC motor and go for a stand alone DC motor. Massive reduction in vibration because the unit is totally isolated (apart from the Belt contact). From what I can see there are two very cost effective options out there.
1) timaudio, 12 volt stand alone DC motor (I have one) very good value money at around US$100, until it goes wrong. Then they are a pain to deal with and they eventually sent a replacement motor. Trouble is it was a 9 volt not 12!!, works OK but I bought the 12 in the first place.
temaadaudio. Again a 12 DC volt motor, (have not tried it) but it is battery driven and costs US$85 and apparently you get over 6 hours use from one charge.
Both sell on Ebay
tabarddn
Old 1st October 2012, 03:13 PM   #26
Thank you sq225917. I will start reading the attached thread. Best regards Moray James.
moray james
Old 17th October 2012, 11:51 PM   #27
YNWOAN is offline YNWOAN  United Kingdom
YNWOAN's Avatar
Originally Posted by Mark Kelly View Post
The second is a resonance between the moment of inertia of the rotor and the electromagnetic torque "spring" caused by the drive current being greater than the stall value at the output torque, which causes the angle between rotor and stator field to reduce. Since this is related to the difference between drive voltage and "generator voltage", the higher the drive voltage the worse this effect. It isn't as easily solved as the above effects and my first attempts were either abject failures or impossibly complex to implement. I'm still searching for a good simple solution to this one.
This is very interesting and is an area that I have investigated (and had some considerable success - sq225917 has taken part in my investigations).
Old 18th October 2012, 11:48 PM   #28
Yes you haven't looked back since first using the silicon fluid from my old Kuzma deck in your LP12 bearing.
Old 19th October 2012, 12:30 PM   #29
YNWOAN's Avatar
Unfortunately, the above post has been misunderstood (my fault - too succinct); what I meant was that sq225917 and I have shared ideas and experience - he has also done a great deal of investigation with regard to power supplies (which I have been lucky enough to participate in - though have had no input).
Old 19th October 2012, 12:55 PM   #30
Thanks for the clarification Mark, I've always found that better outcomes are arrived at when working on a problem with someone else, especially so when working on a problem with you.
Help required for using a FDD motor as a turntable motor. binspaul Analogue Source 5 13th May 2009 03:59 AM
WTD - DC turntable motor + controller copydex Swap Meet 0 12th December 2008 07:54 PM
LRK motor for Turntable? pixpop Analogue Source 1 17th June 2007 03:30 AM
AR XA Turntable - WTB Motor bluemt Swap Meet 0 27th December 2005 05:37 PM
Motor for turntable. Tomek Analogue Source 33 9th October 2003 11:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
