Old 2nd January 2007, 07:08 PM   #1
Default Brass or plastic (type) pulley
Looking for thought...
I have a DIY table with a motor using a brass pulley designed for a flat belt (aka: from an older Kenwood belt drive). I am running my DIY table with an audio cassette tape as a belt and it works well enough. This said I have another motor which came from either an audio cassette deck or VCR. It has a hard plastic-like pulley that is of a narrow groove design for running a thin round or v-belt. I was thinking of trying this on on the other motor shaft to run a silk thread drive for my turntable. I wonder if any of you here have thoughts on which material is better, a wider brass pulley for a flat belt or a thinner grooved plastic pulley for a round or V belt?
Next, I was able to easily pull the plastic pulley off the motor it came with. The brass pulley currently on the motor I'm using is on tighter and I am worried about any damage to the motor if I try to pry this off. Any ideas on doing this with little fear in damaging the motor or shaft?
I really am only considering this for the curiosity of it. I am just wondering if it will improve the performance of my setup or not? The drive diameter of both pullies looks very similar and as my motor is a D.C. servo I have trim pots for fine adjusting speed control.
Thanks in advance.
Old 7th January 2007, 10:14 PM   #2
Panicos K's Avatar
I would go for the grooved plastic pulley(less ringing than otherwise fine brass)and silk thread(less resonance and better stability than rubber belts)
Old 10th January 2007, 11:55 PM   #3
how do you join silk thread without putting a knot in it?
Old 15th January 2007, 10:29 PM   #4
Panicos K's Avatar
Yes you will have to have a knot
Old 20th January 2007, 01:28 AM   #5
I is possible to tie a extremely small inline knot with silk. It would not make the platter skip. It is hard though. Quite hard.
Old 20th January 2007, 09:24 AM   #6
I have made a thread drive using the brass pulley. It rides up near the top (crown) of the pulley, but my speed trim control allows me to get the speed correct. The double square knot with a little dab of super glue makes for a strong connection and the knot does not affect the playback of the table at all. The strobe pattern on a disc remains frozen and the platter runs smoothly. The knot is really quit small and even watching it with your eyes only sees it quickly blip around the pulley. Factoring I have the thread drive taught enough but not so tight that it strains against either the platter or pulley. I am impressed with how quickly the thread gets my 10lb platter up to speed as well and it does not seem to drag as much when I lightly run my carbon fibre brush over an LP cleaning to get ready when playing.
What flux for soldering old brass? Pbassred Solid State 5 5th December 2007 10:35 AM
Brass sub box Piglicker Subwoofers 12 19th June 2006 12:33 AM
FS: Rega tonearm VTA nut (brass) krishu Swap Meet 0 2nd November 2004 04:16 PM
UK Source for brass bar? penance Everything Else 6 4th October 2004 10:49 AM
Brass Buss Bar kilowattski Solid State 6 12th October 2003 07:06 AM
Page generated in 0.08108 seconds (78.43% PHP - 21.57% MySQL) with 10 queries
