Nude Denon 103?
Have any of the members had any experience with denuding a Denon 103? I thought that I'd seen a reference to doing so in a past post, but I've had no luck with a search. I recall that some European music lovers had fooled around with casting a new body out of potmetal, but perhaps there is an easier way to improve upon the stock 103C? Thanks in advance - Pat
I think I posted a link to this on the Vinyl Asylum awhile ago?
The page is in French. <font size="-2"> Pics a link</font>
<a href="http://haute.fidelite.com.online.fr/c-DIY.html"><img src="http://haute.fidelite.com.online.fr/Cellules-Dan/cellule-legende.jpg" ></a>
Hope this helps
James
diyAudio Senior Member
Joined 2002
NUDE 103
Yes,the French journalist who wrote for "L'Audiophile" described the proceding for removing the protection of a 103.
I must have done that myself a couple of times but that is years ago.
From memory the tricky part on the 103 is not to damage the cantilever.
Another problem was that of fixing it on the headshell again after removal due to the 103's particular mounting system.
Most MCs sound much better this way.
Cheers,;)
Running cartridges nude solves different problems depending on what the original design was like. With a metal-bodied cartridge, you get rid of induced eddy currents that would otherwise interfere with the signal generation process.
If you have a plastic body cartridge or a woody :D, the problem solved has more to do with mechanical resonances caused by a lack of rigidity (a problem which the stock 103 has in spades).
If you manage to remove the plastic body of the 103 and still have a functional cartridge :), the next step would be to bond a mechanical brace between the magnet and the end of the center yoke (right behind where the cantilever exits). Non-conductive materials here, please (ceramic or Macor if possible).
As an aside, I believe that I can rightfully claim to be the first person who designed a cartridge from the ground up for nude operation, and the Denon 103 was certainly one of my guinea pigs in working out the do's and don'ts for nude cartridges.
regards, jonathan carr
Ex-Moderator
Joined 2003
Nude Ortofon
Most of the Ortofon moving coils are made in the same way. A top plate has a sproggit onto which the magnet assembly is bolted. They differ in the way that the body covers the internals. The Quattro and its predecessor had a metal body that slid over and was attached to the magnet with two screws. It was a bit unnerving removing the body (nasting cracking sound as glue bonds broke). :bigeyes:
However, because the magnet assembly is only fixed at one point, it tends to resonate, accentuating high frequencies, but this can be effectively damped by a wedge of balsa wood squeezed into the gap between the magnet and top plate. (This can just be seen on the right.)
Once done, the difference in sound was like the difference between a closed box loudspeaker and a baffle - much more open, and (dare I say it?) less boxy. This modification is well worth doing if you have the nerve.
This cartridge died of old age.
1st I need to say it is very risky (at yr own risk always) to open a good cartridge. It may be killed during such Surgery. Most of the time, I open the cartridge because I need to fix the stylus (bended or replacement). I have "killed" and also "killed & rescued" cartridge in the pass. Also, different cartridge body material required different care. The most difficult is marble body (e.g. ruby, ceramic), Resin & compressed plastic and then Metal will be the easily one to receive force. A cartridge is combined with the top and bottom parts to be glued together or sometimes by screws or combined of both method.
Study the body of the cartridge with a watch smith glass carefully again and again until you understand the separation of the top and the bottom before you really hands on the job. The tools are basically a watch smith glass, a set of watch smith screwdrivers, a paper cutter and gasoline (¥Õ¹qªo). The ¥Õ¹qªo is used to dissolve the glue. Test with a little of ¥Õ¹qªo at the end plate (where the 4 gold legs come out) to confirm there is no chemical reaction.
1. Protect the stylus the best way first. (even the whole cartridge is dropped to the floor, it should not be damaged)
2. Wear the watch-smith glass and study the cartridge. This is better to be done under the sun light.
3. After you understand which part is top and the bottom, draw the explode diagram on the paper then go ahead the job.
4. Use a ohm meter to measure the L & R side resistance (i.e. 10-20 ohm) before you start.
5. Use the paper cutter to cut the gap at body of the cartridge where the gap is between the Top and the Bottom parts. !!! Use very light force!!!. You need to cut all the gaps many many times.
6. Apply a little bit of ¥Õ¹qªo at the gap at every round you cut.
7. Repeat the above until you feel you have cut 1mm deepness. Then you can attempt the 1st time to open the cartridge. You don't actually need force to open it. Just use the small screw driver to till at one of the gap (usually the top) of the end plate. If you cannot open yet, repeat more step #6 until you can open a line of 1mm. Use the glass to check if you can see any wire and if it is attached to the shell. If yes, don't open it anymore. If you open the cartridge, the wires will be broken and the it will die immediately. You can have 0.00001 chance to resolder the wire and rescue it.
8.Open another 1mm more and see if you can see the wires or anything dangerous. If yes, STOP go ahead.
9. Finally, the cartridge will be opened 1mm by 1mm . Most of the cartridge should be swing-opened like a door (with like one end fixed by a hinge) but not 100%. Be careful!
10. When you swing up the shell to open, be careful not to damage the stylus (you may have removed the protection already). Some cartridge need to be swing-opened as well as slide-opened at the same time.
11. After you have opened the case (removed the shell), measured the resistance again to make sure it is still alive.
12. WORKING WITH A NO-SHELL CARTRIDGE IS VERY VERY DANGER, its thin wire may be broken even by a light touching so stay away from the wire.
The above are just my experience and practices which may not be the best attempts.
Remember, it is always OK and logical to stop at any step before you damage your own cartridge. I am not responsible for all your damaged and loss. (ref to following picture)
http://i20.photobucket.com/albums/b206/etsang3/DL301Opening.jpg
¥Õ¹qªo is some sort of solvent ?
It is actually the clear gasoline used in small lighter.
It is good stuff to dissolve glue and labels on products.
It is mild solvent than tinner for paint which attacks all plastic except polymer (i.e. plastic bag)
But becareful with gasoline is applied to clear plastic (i.e like windows of toy car), it will break it.
I cannot locate the details of DL-80 even from Denon company page. Just found a picture in ebay of a RED cartridge DL-80. Do you have one and what do you want to do with that ?
Official Court Jester
Joined 2003
I'm asking for ¥Õ¹qªo just because it looks funny ,at least in my browser (Firefox with western page encoding);
but-now I'm pretty sure that its something close to medical benzine or even zippo lighter fluid,even if zippo is maybe something "greasier"?
I have Denon DL80 like nice trophy from one flea market bargain ,where I bought one of cheapest (I presume) Denon TTs - one cheap looking DD plastic thingie with electronically assisted arm etc ;I think that model number is something like DP (or DF?) 23... not sure right now,just because isn't near me now...but what I can say that it sound damn good for that cheap look and lightness ;)
anyway- cartridge is like new,and I'll use it somewhere -on any of my t'tables -L75 or 401 or even 930st ,untill I finnaly put enough money "on the side" for brand new DL103
tnx for your effort,again.
I agree! Also, IMHO, I feel that the original 103C "conical" of 75. was the best sounding mcc. The original 103S "shibatta" was horible. I still have my "original" 103C though it needs to be re-tipped. Anyone know who does this "well"? I am an Audiophile - Technician - DIY'er and would not even think about trying to re-tip this cart..
