| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
DIY !
is to use somthing like this Monster y-split, and solder resistors over a pair RCA-plugs. (or caps, for MM-loading).
Arne K
Ars longa, vita brevis |
#12 |
Although I agree that a rotary switch or parallel rca's will provide the convinience of experimentation,in my opinion these can do more harm than good to the final sound.Perhaps doing such a loading device and use it till you decide what you like more and then solder directly in the phono stage the chosen resistors,would be the best thing to do.It will cost less too.
#13 |
That's the point. Noting that bulgin makes cartridges, he needs a means of quickly and efficiently testing them. The custom decade box would be just for that, not for a permanent installation.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#14 |
EC8010,we agree.
| Moving Coil preamp design | paul joyce | Solid State | 162 | 26th October 2010 10:36 PM |
| What currently available moving magnet cartridge is the best.??????.... | oldheathkitphil | Analogue Source | 28 | 12th April 2008 01:16 PM |
| Meridian 101 moving coil module | RCruz | Analogue Source | 1 | 24th April 2007 10:34 PM |
| Moving coil meter: where to buy? | Thoru | Parts | 4 | 3rd January 2006 03:28 PM |
| moving coil loading | lt cdr data | Analogue Source | 28 | 27th June 2005 09:50 PM |
| Page generated in 0.08417 seconds (62.86% PHP - 37.14% MySQL) with 11 queries |
