Need help on pulley diameter calculation
Hi Guys,
I was able to get my floppy drive motor up and running powered by an old Casio E100 PDA power supply that puts up 5V.
It was very competent turning in the Pink Triangle and Clearaudio platters I have on hand.
I wanted to have a local machine shop make a pulley for me.
Having read Mark Kelly's posts about belt creep and all those Poisson formulas, I think I'd avoid a rubber belt :D and use a casette tape as a belt.
Can someone share the formula I need to use to know the size of the pulley?
Official Court Jester
Joined 2003
arnoldc said:
Hi Guys,
(100/3 x Ddisc )/ Rpm of floppy motor = D pulley
it can't be so easy ........ ;)
Re: Stupid question
enzedone said:
Little confused:confused: over the calculations, Ddisc; is this the diamater of the platter your driving with the motor?
Yes, Ddisc is the diameter of the platter.
To make this straight: The diameter is inversely proportional to the RPM.
Motor pulley Dia Dm / Platter Dia Dp = Platter RPM Rp / Motor RPM Rm
Motor pulley Dia Dm = Dp x Rp / Rm
Din
