killed needle or something else?
Old 2nd January 2007, 05:24 PM   #11
gilid is offline gilid
Default cartridge coil continuity check - danger!
Be careful about putting a ohmeter across a cartridge coil...I once fried a perfectly fine cartridge this way. All meters send a small current across the load under measurement, and measure the voltage drop. Resistance is then calculated from ohm's law.
Even through this current is small, it can damage (permanently) the coils!
Old 2nd January 2007, 07:14 PM   #12
Nordic is offline Nordic  South Africa
Nordic's Avatar
Merci, luckily all went well... meter had low charge on battery ...
killed needle or something else?Hide this!Advertise here!
killed BJT zilog Solid State 4 28th May 2008 07:28 AM
Killed my T-Amp? JWFokker Class D 3 28th March 2007 06:54 AM
I think I killed it. Nappylady Chip Amps 28 11th November 2003 01:24 AM
I just killed my amp - please help me! schnitti Solid State 8 15th September 2003 02:00 AM
Copyright ©1999-2017 diyAudio
