Maxim AN1931: USB-Powered High Precision Phono Preamp
Old 17th December 2006, 08:52 AM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Lightbulb Maxim AN1931: USB-Powered High Precision Phono Preamp
Hello.
lineup here again
My attached circuit diagram shows a nice little new idea from Maxim www.maxim-ic.com
High quality RIAA Phono Pre Amplifier
using your computer USB port for power supply, +5 Volt.
This design, as often when comes to MAXIM IC devices,
has very small mini components, chips.
Mainly intended for SMD use.
IC1.
Power supply regulator MAX8877 is one 5-pin SOT23.
Low-Noise, Low-Dropout, 150mA Linear Regulator
IC2.
Low-Distortion OP Amp MAX4478 is one 6-pin SOT23.
Low-Noise, Low-Distortion, Wide-Band, Rail-to-Rail Op Amp
See my attachment for basic circuit idea.
And visit the webpage for more info.
Basic information in this webpage:
USB-Powered High Precision Hi-Fi Phono Preamp
It is described in Maxim application note AN1931.
Download:
http://pdfserv.maxim-ic.com/en/an/AN1931.pdf
lineup
lineup
Old 11th November 2014, 05:54 PM   #2
lineup's Avatar
Any feedback on this?
lineup
Old 11th November 2014, 10:07 PM   #3
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
only 3.3v rails for a mm phono gain stage?
i don't think so ...
mlloyd1
Old 11th November 2014, 10:51 PM   #4
rayma is offline rayma  United States
That was the design goal, for use on USB.
Old 8th August 2016, 05:40 PM   #5
stocktrader200 is offline stocktrader200  Canada
may sound good, no headroom whatsoever
Maxim AN1931: USB-Powered High Precision Phono PreampHide this!Advertise here!
high precision high voltage supply nhuwar Planars & Exotics 13 12th February 2007 08:24 AM
Battery powered phono. GeirW Tubes / Valves 6 4th December 2004 07:40 PM
minimalistic high end mm phono preamp diy ? miziq Analogue Source 1 9th July 2004 06:08 AM
Maxim high pass filters Optical Solid State 5 20th November 2002 10:26 PM
Copyright ©1999-2017 diyAudio
