| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
Hi Enzedone,
Another way to get the motor: http://cgi.ebay.com.hk/ws/eBayISAPI....arch%26fgtp%3D Best regards, CHOW |
#12 |
Yes you are right, it looks as though all I have to do is remove the resister for the the smaller voltage.
This is great news.
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX. |
#13 |
Enzedone
Check your e-mail. Thanks. CHOW |
#14 |
Chow,
I will check my AC supply first as I think it's running about 230-238VAC from the wall. Maybe I should get one of those strobe mats, to be sure. Anyway I'll just br happy to get it up and running. Brett this TT is really getting, first coming from Germany, Then motor goes to HK, now its coming down here...........
#15 |
Well, the motor arrived the other and it's sure straighter than my old one. I will try to get it together this weekend and see how it runs.............................
Cheers guys Brett
#16 |
Hi everybody
That's my first post in this forum. I use this thread to ask some informations about the TD165 motor. I've received an old TT and I want to put it in function. The first dubt is the motor - it's normal that it can be easy stopped by pressing the pulley with finger ?. I bought new belt, when I switch on the motor it make a low noise (vibrations) for 10-20 s untill it reach the nominal speed. I mesured the resistance of the two windings : 4,2k and 5,6 kohm, can they be different or there is something wrong. I tried to change the resistor, instead of the 5,6k I tried 4,7k and 10 k (with the last it doesn't turn), the problem remains. The pulley has 13,8 mm of diameter, should be 14,0 mm ? I have buy a new one or this a normal behavior of the TD165 ? |
#17 |
That's normal behaviour. Check the platter speed with a stroboscope (there's on on the label of Kraftwerk's "Man Machine").
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| Thorens TD145/TD160 Motor Pulley | Cassido | Analogue Source | 9 | 15th August 2011 02:12 AM |
| CDM1: help please: removal of spindle motor shaft | Steerpike | Digital Source | 24 | 8th December 2010 08:59 PM |
| Bent woodwork Tip | Tenson | Multi-Way | 36 | 9th June 2008 06:17 AM |
| Turntable motor spindle is slightly bent... | Lonestar | Analogue Source | 7 | 25th February 2008 07:30 PM |
| what can I do to a bent tone arm | audio3chung | Analogue Source | 15 | 18th October 2006 01:38 PM |
| Page generated in 0.09554 seconds (75.50% PHP - 24.50% MySQL) with 10 queries |
