Old 30th November 2006, 10:41 PM   #1
MadMutt is offline MadMutt  Australia
Default Nakamichi CA7 Schematics ?
Hi all, Trying to find a schematic of the Nakamichi CA7 Pre amp.
Thanks......
MM
Old 17th December 2006, 06:26 PM   #2
Shaun is offline Shaun  South Africa
Shaun's Avatar
Default Me 2..
Hi MadMutt
I, too have a CA7, requiring repairs to the balance control. If you do find a schematic, would you be so kind as to send me a copy?
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 17th December 2006, 07:36 PM   #3
tvi is offline tvi  Australia
tvi's Avatar
I have a average pdf copy of the schematic.
Email addresses and I send it to you
James
Old 17th December 2006, 09:28 PM   #4
Shaun - Yup same here.
Ended up replacing the balance control completely.
Used an Alps centre detent pot part number 697-928.
Final cost inc our gst and freight came to Au$74.21.
Will post some pics soon for you.
Only hitch was that the shaft on the replacement wasn't the length stated on the site.
I cut the extra needed off the original, cut a slot into the back of this 'extension', and then used two part epoxy to glue them together.
Works just fine, Customer VERY happy.
Tvi - Ta, email is -
f0rum5 at tpg dot com dot au
- note that first word has two numbers in it, a zero and a five.
Old 17th December 2006, 09:28 PM   #5
Pics of the mod for those interested.
Remove ALL resitors under the balance control.
Short across R178 and R278.
Connect new pot using short wires.
(yes I realise I could've done it with less wires, but to me this looked neatest).
Old 17th December 2006, 09:28 PM   #6
And a pic of the topside.......
Old 18th December 2006, 05:18 AM   #7
Shaun's Avatar
Hi MadMutt
Thanks for the info. I had bypassed the balance control, but that caused the 3-way tone controls to malfunction, so I have the tone control bypass function permanently selected.
Who did you buy the pot from?
Shaun Onverwacht
Old 18th December 2006, 08:39 PM   #8
Oops sorry, Farnells.
Hope it helps.......
Old 18th December 2006, 08:52 PM   #9
Shaun's Avatar
Hey, it must have been fun taking out that switch!
Shaun Onverwacht
Old 18th December 2006, 09:09 PM   #10
Quite easy really.
Owner/friend previously complained about crackling, so I had already sprayed it with progold (Caig labs) lasted for almost 2 years.
He started complaining again so I suggested he disassemble and spray himself.
He tried to cheat and not pull the front off to remove the black plastic cover, he ended up cracking 2 wafers.
So back it came for me to replace it.
Remove all knobs (not the volume one).
remove top and bottom covers.
remove front extrusion (watch for wire near left side).
remove front circuit board (only need to unscrew so it can be moved a bit).
undo volume control flexi joint (small allen key).
unbolt front sub panel (dont forget the control shaft nuts).
This allows you to move the front sub panel foward enough so that once the control is unsoldered it can be removed.
Forgot to mention, if you want the best for the unit, while its apart,
I also recomend replacing the opto couplers (look like white i.c.'s).
Their cheap and make quite an improvement to the overall sound of the unit.
Can't remember, but if theirs a memory batt/cap it will be crying out to be replaced by now too.
that should keep you busy for a day.
Nakamichi CA-5 hum/buzz and does anyone have the schematics/service manual? IG81 Solid State 1 3rd June 2009 01:58 AM
Nakamichi PA-1 Schematics gto127 Solid State 0 18th February 2009 05:03 PM
Need Nakamichi TA-4A schematics gto127 Analogue Source 0 3rd September 2007 10:13 PM
WANTED: Nakamichi TD-45Z Schematics Zero Cool Car Audio 6 22nd June 2006 11:21 PM
Schematics Nakamichi CD player 2 Guido Tent Digital Source 1 2nd April 2004 01:57 AM
Page generated in 0.09993 seconds (77.51% PHP - 22.49% MySQL) with 11 queries
