Old 28th June 2007, 04:34 PM   #31
For small projects, Erno is still a good source for fets. They now cost even more in the open market in many cases. There isn't any clear way to save money or to substitute parts, UNLESS you are very lucky. Think of these devices as if they were discontinued tubes, and perhaps you can gain better perspective.
Old 3rd September 2007, 04:32 PM   #32
h_a is offline h_a  Europe
h_a's Avatar
So I'm curious - has somebody build this phono pre in the meantime?
As I'm no expert, maybe someone could help me a bit to understand this circuit a bit better: the SCP-2A shown here consists of SCP-1 and SCM-2 (though Stereophile claims that SCP-1 is only the power supply, ahem).
How much gain has the SCP-1?
I read in Frederico's notes 40dB@1kHz...is that correct? And as far as I can see there is only 1 RIAA-time constant realized in the SCP-1 with R16||C7, is that correct?
Consequently SCM-2 delivers another 20dB gain to give in total 60dB and further passive RIAA-equalization, correct?
Is there any suitable way to use Moving magnet cartridges with this design?
Thanks a lot for taking the time!
All the best, Hannes
Old 3rd September 2007, 05:07 PM   #33
The SCP-1 was a separate design that stood alone, for several years. It had a flat linear gain of about 25. Dave Wilson still uses an SCP-1 in front of virtually all of his phono preamps that he has used, over the years.
The SCP-2 includes an SCP-1 board and an SCM-2 board which adds further gain and equalization.
This design is NOT designed for moving magnet input, because it is difficult to control the gain, without changing the frequency response. Also, the input parts have too high nonlinear input capacitance to be driven by any cartridge over 100 ohms in impedance. It is just the wrong design for moving magnets.
Old 4th September 2007, 01:31 PM   #34
h_a's Avatar
John Curl, thank you very much for your enlightening reply!
Especially your point about max. cartridge impedance I find very interesting and useful!
It's a pity that I wouldn't be able to use a SCP-2 at the moment, but I'm thinking of building it nevertheless, it's such a cute design!
Old 17th November 2007, 07:59 PM   #35
kamis is offline kamis  Serbia
I expected this thread to be more responsive. After all, Vendetta phono is also the part of Blowtorch preamp which is a subject of a separate, huge thread. Recently,I have bought a few tens of J175 and J112 at a very good price at my local electronic parts supplier,for Vendetta first stage local regulators.They are from the same batch, well matched components,generally to about 3-7 % of Idss. I wish to ask mr Curl if it is good matching for voltage regulators paralleled transistors.
Also, in a previous thread, he mentioned Harris 1A vertical Mosfet used in cap. multiplier/filter circuit. Searching catalogues and datasheets, i was not able to find such a part.
Old 18th November 2007, 12:02 AM   #36
The problem isn't the quality of the design, it's that so many people have abandoned the LP as source material. If you don't listen to records, you don't need a phono stage. It's that simple.
Harris no longer exists as a separate corporation. They were bought out. In fact, one of the more available alternatives, IRF, recently sold their MOSFET division to Vishay. Your best bet at this time is to look for either Toshiba or Hitachi parts that meet the same general specifications, assuming you can find them. If you can't get them, the fallback position is Fairchild.
Grey
Old 18th November 2007, 12:24 AM   #37
Kamis, you should be OK, IF your paralleled devices track to a few mils of each other.
Old 18th November 2007, 05:59 PM   #38
h_a's Avatar
Well, initially I also thought so.
However it's not so easy. First, the schematic is thought to be correct, but it was never build (at least nobody here said otherwise), so there might still be mistakes. Thus you would want to own some equipment (signal generator+scope) to test it.
Further it uses hard to find parts which need to be matched as well (so you need lots of them). If you start substituting parts, it's not a real Vendetta anymore; however at least you need to know with which parts you can replace the originals.
Next the Vendetta copes exclusively with MCs, so people with MMs drop out of the equation.
In a couple of years I will build one, but I guess that's a tad too far away for you, eh?
Old 18th November 2007, 11:23 PM   #39
On the other hand, you've got people like me who have multiple moving coil cartridges on hand. But I feel no compunctions whatsoever about changing devices around to suit my availability/needs/wants/desires/mood. You can do one helluva job using the 2SK389/2SJ109 and 2SK170/2SJ74 for the main gain parts. The MOSFETs are wide open--Toshiba/Hitachi/Fairchild/IRF/etc. I recently acquired some of the Toshiba MOSFETs (and John thinks people never listen to his suggestions...huh!) and have had very good results in another circuit I'm working on. I have a phono stage going as well--it will receive some attention in due time.
Don't obsess over the parts--work the topology with parts that you can get.
Grey
Old 19th November 2007, 12:07 AM   #40
zeonrider's Avatar
Default Hi!
Question for kamis:
Where you bought J175 and J112 ?
Regards zeoN_Rider
Vendetta research Miguel_Angel Everything Else 3 26th December 2007 01:19 AM
Vendetta crossover tomtt Solid State 0 1st July 2007 12:52 AM
A Real Sub mikee12345 Multi-Way 10 10th March 2003 03:03 PM
Combing effects: How real in "real" rooms? smeade1079 Multi-Way 3 10th March 2003 01:32 AM
Page generated in 0.17100 seconds (61.05% PHP - 38.95% MySQL) with 11 queries
