Old 18th November 2006, 01:43 PM   #1
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default Matching Beyer M55 and Philips EL6431
I've got this classic Beyer M55 microphone and would like to wire it correctly to the mic input of the Philips EL6431.
Microphone comes with three wires and a shielding, amplifier mic input has the three plugs, hot, cold and ground.
Full schematic of EL6431 here.
I have no data on the M55 except this picture:
http://users.pandora.be/oldmicrophon...beyer_m55.html
/Hugo
Old 18th November 2006, 01:44 PM   #2
Netlist's Avatar
Din plug from M55:
Old 18th November 2006, 01:47 PM   #3
pinkmouse's Avatar
IIRC, the M55 had a specific PSU/pre, so I would imagine that the fourth pin is for HT.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 18th November 2006, 02:03 PM   #4
Netlist's Avatar
That was quick. I'll wire the hot to hot and see how far I get with grounding the other pins.
/Hugo
Old 18th November 2006, 03:42 PM   #5
Netlist's Avatar
Fixed...without hum.
Here's a picture for those among us interested in this old powerhouse.
/Hugo
Old 10th December 2006, 11:52 AM   #6
OldAmps is offline OldAmps  United Kingdom
Default changing beyer m55 din plug for xlr
Hello,
iv'e just picked up an old m55 and want to rewire it with a male xlr connector to replace the 3 pin din.
It is identical as the picture above with a three core cable plus a shield. How should I wire this to the xlr ? Other mics I have wired have used to a two core plus shield. Do I need to bridge the pins, or wire the shield somewhere else?
Any help would be greatly appreciated as would any opinions on the m55 and its uses.
Many thanks.
Old 10th December 2006, 11:59 AM   #7
Netlist's Avatar
Oldamps, welcome.
Honestly, I forgot. I played around with the wires till I found the good combination. Can't be that hard with only three pins.
/Hugo
Old 10th December 2006, 07:37 PM   #8
Had a mess about with the wires and all is working now and sounding nice!
Realised that connecting either the blue or white wire to xlr pin 2 decides the hi or low impedance, the other is not used. White lo, blue hi.
cheers
Old 10th December 2006, 07:57 PM   #9
Netlist's Avatar
I had a quick listen to the M55 last time and believe it must have been a reporters microphone. Small, robust, handy and a perfect 'Hi-Fi' quality for AM broadcasts.
I could be wrong of course.
-=Hugo=-
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
BEYER 700 series capsule (i need) tgregorek Swap Meet 0 22nd July 2009 11:30 PM
Beyer MM-1 RTA Mic Best Budget RTA Mic Zero Cool Swap Meet 3 5th May 2009 05:32 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Beyer Dynamic BV35570 victor3123 Tubes / Valves 0 23rd December 2007 01:06 AM
Page generated in 0.84722 seconds (3.16% PHP - 96.84% MySQL) with 11 queries
