| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi everyone, I have got a thorens TD160 with a original tonearm
but sadly bent at the rear part, should anyone has the same experience and tell me what can I do, to find another thorens tonearm in HONG KONG is quite difficulty. I perfer to disassembly it and re-straight it. Thanks, CHOW |
#2 |
The first thing I would do is strip it down completely then you can see what the real damage is. What's the arm made of?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
yes you must strip it down ,then look what you can to repair damage
post picture when you dismantle it . be careful with bearings and wiring to pink-Thorens,alu tube.
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#4 |
Hi Chow
This looks like a nice enough arm to have a go at fixing. The armtube looks like a thinwall alu tube? Depending on how the armwires enter the armbase (by plug and socket or directly), you'll have to remove the complete arm from the tt. Once this is done, remove the armweight. Is there a spiral grooved plastic stub for the weight at the back? If the stub is hollow, there'll be a selftapper inside to remove the stub. There should be 5 wires in the armbase: red, green, white and blue and a 5th, which should be black, connecting the armbase to the armtube itself. Once you have removed the arm from the tt, removed the weight stub etc, try to post more pics like the esteemed pinkmouse suggested, so we can assist you further. Whatever will have to happen, the armwires will have to be removed from where they could get damaged. Most likely, the armtube will also have to be removed from its pivot. With a little bit of luck, a tube bending spring could be inserted and the bend carefully pressed in a soft jaw vise or a lathe headstock chuck for better trueing. Good luck bulgin |
#5 |
Thanks for your suggestion, I think it is worth to have a try, will post pict once I have strip it down.
Regards, CHOW |
#6 |
BTW If someone can poitnt out where can I get the assembly
diagram of this tonearm( I dont know the exact model, maybe a TP16).This surely will make the job more easy. Thanks, CHOW |
#7 |
If possible, strip the arm down so that you just have the tube. Plug one end and fill the tube with moist fine sand. Pack it in there good. Plug the open end. Now you can bend the tube without fear of crimping it. I have used this method on tubing successfully several times.
#8 |
Yes, it looks like a most safe way to bend or straighten a hollow tube, surely I will take a try provided I can de-assembly the tone arm.
Regards, CHOW |
#9 |
It looks like it ought to be fixable (with care). I would check to see if there is any associated bearing damage to be repaired, too, since it probably took a pretty good whack to bend it that much.
#10 |
I have strip the tonearm and find an arm tube like this, I manage to make it quite straight and assembly the whole thing, it now play LPs well, but can any one tell me where can I get a 50Hz motor pulley for the TD160 because I get one TT with 117v 60Hz motor, how stupid I am. Thanks CHOW |
| Bent woodwork Tip | Tenson | Multi-Way | 36 | 9th June 2008 06:17 AM |
| Bent HP meter pointer | anatech | Parts | 57 | 3rd June 2007 05:18 AM |
| Bent Audio Noh preamp | lt cdr data | Swap Meet | 0 | 7th July 2006 05:54 PM |
| WANTED: TVC Bent, Django, etc | riotubes | Swap Meet | 1 | 29th March 2006 02:32 PM |
| Grado MF1 Stylus Bent... | Modernaire | Analogue Source | 32 | 16th April 2004 07:53 PM |
| Page generated in 0.10515 seconds (77.08% PHP - 22.92% MySQL) with 11 queries |
